4agze flywheel details
Postby gasman » Mon Mar 03, 2008 7:45 pm
whats the pressure plate bolt spacing details of the late ae92 4agze and ae101 4agze flywheel? because on the exedy website it says its 253mm pcd but i got a pressure plate with me here which i assume is for a late 4agze and is about a 263mm pcd.
does anyone have a flywheel handy that they could measure it off or even get a piece of paper and a crayon or something and do a impression of it and send it to me.
"What can possibly go wrong?"
gasman
Postby bluemaumau » Mon Mar 03, 2008 9:09 pm
ive got one. you want the OD of the clamping surface? or where you bolt the pressure plate to?
Postby gasman » Mon Mar 03, 2008 9:10 pm
where you bolt the pressure plate onto the flywheel. (6 bolts?)
gasman
Postby bluemaumau » Mon Mar 03, 2008 9:16 pm
so you wan tthe distance from one bolt hole to the opposite bolt hole, correct?
Postby gasman » Mon Mar 03, 2008 9:23 pm
yea. picture also if you can
gasman
Postby bluemaumau » Mon Mar 03, 2008 9:39 pm
252mm is what i got. from center of bolt hole to the opposite center
so yea its prob 253
Postby gasman » Mon Mar 03, 2008 9:41 pm
hmmm thats interesting, wh clutch pressure plate have i got then? guess ill just run the older style clutch.
thanks for you help
gasman
