rollaholic wrote:pretty light on details for a claimed 196 hp NA...
strx7 wrote:rollaholic wrote:pretty light on details for a claimed 196 hp NA...
the 5.3:1 diff ratio helps iy make at 196 @ the wheels a fair bit. put a 4.1:1 in there and i'd probably only make 170 something
RomanV wrote:strx7 wrote:rollaholic wrote:pretty light on details for a claimed 196 hp NA...
Heh... If this was true, then you'd make more HP in 3rd gear than 4th.....
lower gear = more torque ATW, but at a lower speed, so HP = the same.
RomanV wrote:Heh... If this was true, then you'd make more HP in 3rd gear than 4th.....
d1 mule wrote:yeah everyone says its cheaper to buy, but........ if your building one yourself you generally dont go fork out 30K in one day do you, $1000 here, $1500 there, $400 there etc etc, it takes months if not years to get to that sort of coin, so i think yeah its probably good value but bloody expensive none the less
method wrote:Id rather this one!
Users browsing this forum: Bing [Bot] and 20 guests
