Right front wheel/brake making a funny noise
Postby Warren » Fri Mar 07, 2008 8:04 am
Hey all,
Been car pooling for a while to work and the person I catch a ride with has a Nissan Primera Station Wagon.
Every now and then it makes some sort of sqealy/screetchy noise or metal on metal conact. It does at complete random times, i.e. when the car has been traveling for 5mins or 1 hour etc, hot day or cold day etc etc.
But when the brakes are applied the noise goes away but comes back when you let off the brake, but if the brakes are applied hard enough and long enough the noise will dissapear for good until it decides to come back at random.
I thought it could be a dry bearing or something but I'm not sure.
Thanks for any help in advance.
Warren
Mr. T says "Don't do school, stay in milk, and drink your drugs"
Warren
Postby GDII » Fri Mar 07, 2008 9:11 am
I want to know that to. My Mums Corolla Wagon does that to. I have checked brake pads, they seem fine. Wheel bearing doesn't seem to be broken.
But when I jack up the car the brakes seem to be gently rubbing on the discs and the wheel is hard to turn and won't spin for long. 1/2 or 3/4 turns then stops.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Voyeur » Fri Mar 07, 2008 9:42 am
1) binding slides on calliper
2) partially seized calliper
3) warped disc
4) no anti squeal pad
5) pads worn down to indicator
6) glazed pads
Anybody else
2005 vz ss commodore
Voyeur
Postby Warren » Fri Mar 07, 2008 10:40 am
Yeah sorry forgot to mention that the brake pad is fine, the disc isn't warped either.
Warren
Postby Trls250s » Fri Mar 07, 2008 11:15 am
Its not bjorns car is it?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Warren » Fri Mar 07, 2008 11:37 am
Yeah it is.
He's taken it to his usual mechanic, and he took the wheel off and had a look but could'nt see anything unusual. He even took it for a drive but of course nothing happened of course, surprise surprise. Cars seem fix themselves when you take it to a mechanic :?
Warren
Postby Trls250s » Fri Mar 07, 2008 11:45 am
Theres not much in them that can really go wrong.
He should sell it, its a piece haha CVT gearbox :S
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Warren » Fri Mar 07, 2008 12:00 pm
You mean, not much that can't go wrong? haha
Yeah CVT gearbox *shudders*
Warren
Postby THA SHZ » Fri Mar 07, 2008 1:33 pm
look to see if it has all of its pad stabilising clips in it , they hold the pad in place , if even one is missing it willo do what yoiu are describing as the pad will move 8)
THA SHZ
Postby myk00l » Mon Mar 10, 2008 7:10 am
Put a thin smear of grease on the side of metal backing plate(anti squeal pad) that goes against the back of brake pad. Just don't get any grease on friction surface of brake pad.
myk00l
Postby Mr Revhead » Mon Mar 10, 2008 8:29 am
dont use grease
use the proper stuff!! grease melts
Postby myk00l » Mon Mar 10, 2008 9:19 am
Mr Revhead wrote:dont use grease
What is the proper stuff?
myk00l
Postby Mr Revhead » Mon Mar 10, 2008 9:25 am
some coppercoat stuff
or wurth do a proper brake paste
if you just use normal grease it melts and runs out and stops doing the job
not to mention the other possible issues with a leaking lube stuff around ya brakes!
Postby NZVengeance » Mon Mar 10, 2008 10:46 am
i had this happen ages ago on my gt4. took me ages to figure it out. turned out to be a bent dust cover.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
He who dies with the most Toys wins!!
NZVengeance
Postby AE82 FXGT » Mon Mar 10, 2008 6:15 pm
I was going to mention the backing plate^^.
Another cause I've found that'll do that is small stones caught somewhere in the caliper. Did the mechanic remove the caliper as well or just the wheel?
Other than that all other causes I know have been listed
AE82 FXGT
Postby rolla_fxgt » Mon Mar 10, 2008 9:14 pm
I'd be checking the caliper for sticking, i have 1 that every 18months or so decides to stick, but it doesn't look buggered from the outside, but when its taken apart its clear its in need of a new seal kit, try that & see if it works
rolla_fxgt
