trd quad throttle bodies
Postby carter_4 » Wed Mar 26, 2008 1:40 pm
hi guys, i came across these..
http://trdparts02.jp/english/parts_engine-3s-ge.html
(near the bottom of the page)
and was looking at getting some for my 3sge altezza, i was just wondering if anybody has had anything to do with these before? what kinda price id be looking at?
and how much trouble they are to install?
i realise i will need an aftermarket ECU, as i will have to get rid of the MAP sensor in order to install it.
any help is much appreciated,
carter_4
Postby Mr Revhead » Wed Mar 26, 2008 2:54 pm
go get some ae111 blacktop throttles and use those instead :wink:
you will need to make up a manifold for them
atmosports off here does some manifolds, maybe you could get him to do one
Postby fivebob » Wed Mar 26, 2008 2:58 pm
Postby RunningRich » Wed Mar 26, 2008 3:24 pm
fivebob wrote:Also have a look at http://www.alloyrace.com/inlet_manifolds.php
Check out the length of the Alfa Twin Spark manifold! Can you say torque! :D
Wonder how much $$$ though... :roll:
Richard
http://gtfour.supras.org.nz
RunningRich
Postby carter_4 » Wed Mar 26, 2008 3:58 pm
cheers for that guys...
hmm wonder how much, think i might give them an email an ask about pricing.
would there be any significant difference between something made from there and something from trd?
carter_4
Postby nz_climber » Wed Mar 26, 2008 3:59 pm
talk to Celica RA45 on here, he makes adapters for 20V throttle bodies, also has custom 50mm throttle bodies and all sorts of other goodies I wish I could afford
nz_climber
Postby Mr Revhead » Wed Mar 26, 2008 4:09 pm
carter_4 wrote:would there be any significant difference between something made from there and something from trd?
price!
the blacktop ITBs are the same as they use in the TRD ones....
the TRD manifold will have been dyno tested too. but quite probably for max power at high RPMs. which may or not suit you.
if you buy from someone who knows what they are doing (as all options above do) you shouldnt have any issues.
Postby carter_4 » Wed Mar 26, 2008 4:37 pm
oh yea whoops, should of said any significant different in performance!
ill definately have a look around for black top throttle bodies though and get a hold of the people listed above, cheers guys.
does anyone know if there will need to be any significant changes apart from the computer? im assuming an aftermarket ECU will be able to deal with the new intake set up. im pretty sure im going to have to do something with the throttle cable, how difficult or easy that will be i have no idea though
carter_4
Postby stalker » Wed Mar 26, 2008 6:15 pm
I had fun with my engine stalling all the time. (4age with trumpets running a link ecu)
I got it dyno tuned at hytec and it runs sweet now...just make sure where ever you get the ecu tuned that they know what they are doing with that style of intake
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby carter_4 » Wed Mar 26, 2008 6:34 pm
cool cheers man. yea will definately look into getting it tuned at the right place.
did u find a noticeable improvement in power?
carter_4
Postby stalker » Wed Mar 26, 2008 6:47 pm
Cant really say sorry...I brought the car with the trumpets on so I dont know what it was like prior.
But im putting out 118Kw (at the fly) and from what I can see, its only got the tumpets done to it, nothing else. (and ecu of course)
:lol:
stalker
Postby carter_4 » Wed Mar 26, 2008 7:28 pm
haha fair enough..
sounds good enough to me though
carter_4
Postby Celica RA45 » Fri Mar 28, 2008 11:27 am
theres about 25 hp gain with the quad set up and trd does use 45 mm black tops for the motor ,which i have changed to 50mm for more power through the rev range
i also make inlets to suit this motor ,it is very similar to the TRD inlet and is set up for toyota quads if this helps
Celica RA45
Postby gepsk8 » Fri Mar 28, 2008 5:48 pm
how do u changed to 50mm?
modifying? changing?
how much?
O272754663
gepsk8
throttles
Postby Celica RA45 » Fri Mar 28, 2008 10:42 pm
i have made 2 patterns from a black top quad made it thicker in the walls etc then get them cast up heat treated machined to either 48mm or 50mm make new butterflies and linkages new bearings and new seals ,springs etc in the fiish look very similar to a black top throttle
they are 1230 aussie a set of 4 with linkages bar the center 1 which costs 200 aussie or from TRD 350 plus postage
the inlet manifold is a pattern as well same trhing cast heat treated and machined up these cost 600 aussie half of what TRD sells them for
Celica RA45
