VVT mod Does this work?
Postby rally4life » Thu Mar 27, 2008 3:48 pm
After years of thashing my holden Barina around the local hillclimb circuit in the AKL north aera i ve made the purchase and bought a 92 levin gt apex 20v, this is almost finished manz rollcage and race seats c56 gearbox with LSD, next was to see if there was some basic mods and have a read aronud the forums on toyotas and found Toyspeed most helpful- thanks to you all, I dont want to do to much to the motor as yet but some easy mods could be on this is one i have found and would like some feedback on what you think or know
Modifying VVT : is to install a manual switch to earth so you can control when the VVT is on or off. This would only be used once warmed up and on a special stage my goal would be to incress touqe
Suspended in a state of bliss!
[Too much oil in my blood]
ae101 Levin rallycar
suzuki GTi rallyca [for sale]
ae101 Trueno roady[some times parts car]
Izuzu tug for rallycar and daily 4 wife
rally4life
Postby barryogen » Thu Mar 27, 2008 4:09 pm
I'm going to go with not such a great idea.
I mean a bit of VVT-i tuning may be in order, but I'd think that unless you're changing cams etc that there would be little advantage if any to making it switchable.
barryogen
2ZZ Guru in training
Postby Alex B » Thu Mar 27, 2008 4:34 pm
Its not VVT-i they are diffrent.
Postby barryogen » Thu Mar 27, 2008 4:39 pm
it says vvt-i in the subject, I ass-u-me'd it was correct.
dunno then, ignore my comments.
barryogen
Postby sergei » Thu Mar 27, 2008 4:57 pm
Not going to gain anything (apart maybe some weird looks for lumpy idle).
VVT is on anyway until it reaches 6800-7000rpm then it switches off, at that point you will be grabbing another gear.
Postby Mr Revhead » Thu Mar 27, 2008 4:59 pm
nope, leave it as the ECU switchs it
it switchs on when warm pretty much straight away anyway
so no point at all
Postby rally4life » Thu Mar 27, 2008 4:59 pm
Sorry guys i have changed the title - I have 2 Toyotas a late model corolla
with VVT-I my levin has VVT
rally4life
Postby rally4life » Thu Mar 27, 2008 5:02 pm
At what rpm does the VVT switch on /
rally4life
Postby sergei » Thu Mar 27, 2008 5:03 pm
Leave VVTi alone as well. it is continuous and has map on its own. VVTi is not just ON/OFF but it is PWM controlled which changes timing continuously.
Postby sergei » Thu Mar 27, 2008 5:09 pm
rally4life wrote:At what rpm does the VVT switch on /
from idle, providing there is enough throttle open to trigger.
Postby flygt4 » Thu Mar 27, 2008 5:09 pm
from his original post it looks to be VVT as found on silvertop.
pretty sure some people have tried playing with VVT on dyno and found that the factory setup is ideal.
flygt4
Postby xsspeed » Thu Mar 27, 2008 5:29 pm
whats the diff between vvt and vvt-i ?
i cant remember exactly, s/top has vvt right? so what bout b/top?
Postby ®usty » Thu Mar 27, 2008 5:51 pm
so what toyota's just have VVT
®usty
Postby flygt4 » Thu Mar 27, 2008 6:10 pm
pretty sure silvertops run VVT only.
i think VVT-I is infinitely variable, the i standing for intelligent. its always changing depending on engine load, rpm, gear etc etc. ie there is no definable switching point/amount.
it came on 3SGE in caldina (intake only) , 3SGE in mr2 and altezza (intake and exhaust), its on the toyota echo in the 1500cc engine found there, after 2000 pretty much every small engine was using some kind of VVT-i.
VVT was the original version which i think has the set switching point.
i'm unsure which the blacktops use though.
it doesnt really make much more power , just improves torque down low.
flygt4
Postby Bling » Thu Mar 27, 2008 6:33 pm
xsspeed wrote:whats the diff between vvt and vvt-i ?
both VVT, don't believe what some sites say about this.
Postby cogent » Thu Mar 27, 2008 6:35 pm
silvertop VVT seems to be done on throttle position and water temp rather than the vtak styles RPM trigger.
cogent
Postby Mr Revhead » Thu Mar 27, 2008 7:02 pm
yep
varible timing is done according to the ECU map etc
valve lift (like 2zzge) is RPM switched.
VVT in the 4ages is not RPM switched
Postby matt dunn » Thu Mar 27, 2008 7:37 pm
VVt is simple, the ECU turns it on or off and know's it is on or off.
VVT-i is infinatly variable and can be on off, partly on, 1/4 on, 3/4 on,
what ever the ecu wants,
BUT the ecu needs to know where the cams are, think of it as closed loop VVT,
so it needs a camshaft postion sensor on each camshaft, as well as one on the crankshaft so is way more complicated.
Postby Alex B » Fri Mar 28, 2008 12:17 am
flygt4 wrote:it came on 3SGE in caldina (intake only) , 3SGE in mr2 and altezza (intake and exhaust), its on the toyota echo in the 1500cc engine found there, after 2000 pretty much every small engine was using some kind of VVT-i.
Pretty sure the redtop 3s as in MR2 are only on inlet cam.
Postby ®usty » Fri Mar 28, 2008 8:46 am
so VVT is not in Celica (but only as VVT-i in SSII & SSIII 97 -99)
right?
®usty
