bhg? yeh, nah?
bhg? yeh, nah?
Postby Mike- » Sat Mar 29, 2008 3:56 pm
my levin had a milky oil cap, and bubbly water, i pulled the head off, there was a little coolant in no1 cylinder but the head gasket doesnt look like its blown, so after a second opinion
Mike-
Oh my
Postby Capin-Neemo » Sat Mar 29, 2008 4:07 pm
that headgasket looked pretty $&#$% man if that was me id be all like holy shit!
Capin-Neemo
Postby AE82 FXGT » Sat Mar 29, 2008 4:59 pm
If in doubt get the head crack tested and checked to see if warped etc.
But yeah headgasket isn't flash.
AE82 FXGT
Postby deaf_rattle » Sat Mar 29, 2008 6:57 pm
the head gasket can look ok after a bhg.
if no obvious damage it might be worth getting the head checked out.
But if you dont care too much, slap a new gasket in and see how you go.
Postby tsoob » Sat Mar 29, 2008 7:35 pm
yeah man pressure test i didnt and now gotta redo it.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Dell'Orto » Sat Mar 29, 2008 10:42 pm
Kinda hard to tell but it doesnt look blown. The bore binder on #2 look a bit mucky, but might just be the light.
Edit: Wait, the top of #4 looks like it might have burnt through.
Postby Capin-Neemo » Sun Mar 30, 2008 6:14 am
from a closer look at that id be getting a leak test done for sure maybe a cracked water jacket but unlikely. Id pull the hole thing down clean and inspect everything just to be sure. Don't wanna pay for gaskets then have it leak in 3 weeks again.
Capin-Neemo
Postby Mike- » Sun Mar 30, 2008 8:26 am
do you reckon just the head or the block aswell?
Mike-
Postby Capin-Neemo » Sun Mar 30, 2008 9:17 am
id ckeck the block to be on the safe side ive had a couple of honda engines ive worked on and the water was leaking into the cylinders from the water jackets... graned they were hondas but better to be sure then spend all that time rebuilding it just to have is leak still.
Capin-Neemo
Postby Mike- » Sun Mar 30, 2008 10:21 am
ok sounds like the blocks comin out too, does anyone know a good engine reconditioner in henderson, central park drive area?
Mike-
Postby matt dunn » Sun Mar 30, 2008 10:27 am
have found the same thing the few times I've done a head gasket on a 20V, cant see anything but it was blown.
Make sure you get the head surfaced as that was the problem on the one's I have done. a surface and a new gasket adn the were 100% better.
Postby Lloyd » Sun Mar 30, 2008 10:35 am
As Dell'Orto said, gasket could be a little bit sus around the top of number 1/4 (its too early to think which end it is).
Get the head checked and surfaced regardless. Personally I wouldn't bother with the block, would be very unlikely for a cast block to warp unless you have had it stupidly hot
Postby Mike- » Sun Mar 30, 2008 1:16 pm
yeh definitely getting the head surfaced and pressure tested, just worried about the water jackets in the block really
Mike-
Postby YeMs » Sun Mar 30, 2008 1:44 pm
Dell'Orto wrote:Kinda hard to tell but it doesnt look blown. The bore binder on #2 look a bit mucky, but might just be the light.
that would be my guess too.. i dont think there is much to be gained by pulling the block out tho mate. just gunna be more hastle than any thing, and the chances of any thing goin wrong in the block is slim to none realistically. get the head pressure tested and surfaced. chuck a new gasket on and away you go. if it was blown, it hadnt been blown for long. generally the piston gets a schweet steam cleaning and comes up all shiny which is a sure sign of which cylinder it blew on.
Your local Hybrid Elite tech
YeMs
