4A clutch compatability
Postby RS13 » Mon Jan 01, 2007 7:50 pm
Hi guys,
Bascially, I need to know what clutches interchange between the FWD 3A/4AC/4AFE/4AGE factory clutches.
I'm looking to replace the badly slipping clutch in an AE82 with 4AC (sohc carb), with a secondhand jobbie, (car has 4/5 months left on wof, then is being derby'd, so not much point getting brand new!) but I need to know what I can pull a suitable clutch off.
Any help would be great, or if you're in Chch with a clutch that would do the job, I'll gladly take it off your hands!
Cheers. :)
RS13
Postby Bling » Mon Jan 01, 2007 10:35 pm
PM Crispy86, i'm sure hes got a half worn clutch lying around to flog off to fund his race car 8)
Postby RS13 » Mon Mar 31, 2008 5:38 pm
Well, over a year later, this car still lives, with the same slipping clutch that its' had for nearly 160,000km of its' 270,000km.. so help me get this car to 300,000km!
I don't have a transaxle code on the chassis plate, only AE82R etc.. is there a code on the gearbox somewhere (had a look, can't really see anything), or does anyone know flywheel size/spline count etc? I'm still after a secondhand clutch, basically wanting to know wether I can use one off a blue/red/silvertop 4AGE or whatever.. sizes would be marvellous. :)
And if you've got one lying around that would suit, let me know, cheers. :)
RS13
Postby RS13 » Mon Mar 31, 2008 6:25 pm
And also any hints and tips on doing a FWD Corolla clutch, I've never done one, only Nissan and Honda FWDs.. do the CVs pop out as per normal, or do I have to undo the bolts on the driveshafts? Do I just drop the shock out, and leave the outer CV in the hub, and pull the box off as per normal as well?
Any help = sweet. :)
RS13
Postby xsspeed » Mon Mar 31, 2008 6:31 pm
detatch steering rod ends, undo bolts/nuts under balljoint on a-arm, drop arm off hub, cv's pop off, your away
Postby RS13 » Mon Mar 31, 2008 6:55 pm
Detach steering rod ends? I've done nearly 20 fwd clutches, never had to do that yet, is that really a Corolla thing?
RS13
Postby ee904age » Mon Mar 31, 2008 7:00 pm
AFAIK they have flanges on the inner CV's, just unbolt them and Helens your uncle. Better than taking the outers outta the hub.
4AGE's use a bigger clutch (1/2" an inch i think) so you will need a 3A or 4A one
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby xsspeed » Mon Mar 31, 2008 9:13 pm
makes it easier to get the cv's out but they do squeeze past if you just drop off the suspension.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
