http://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html
just a bit more info on them for ya
http://users.tpg.com.au/users/loats/tec ... boxes.html
myk00l wrote:Here are three W55/57/58 clutch forks that are all different. 5MGE, 18RG/21R, and 3TGTE.
Anyone got pics of clutch forks from G52 or W55/57/58 L/2L/2L-T, 2Y/3Y/4Y, 2RZ/3RZ or 1S?
[/quote]AE25 wrote:1s/2c = R the bendy one
5k/g52 km36 looks like the M one with the notch out of the side
colin dray once said to me there were 3 forks for w55/57/58 etc alloy supra box types, the straight, the notched and a 3rd which im guessing is the bendy
they are not the same.. ie different in length between the pivot and the bearing and also between the pivot and the clutch slave contact point.
its about time someone made a comparison list!
notched = M, K,
straight = T, G,
bent = R, S, C,
<--- T and G (straight)
wanted to know...
JZ, RZ, L, Y,
also interested to know... are there variations found on the same engine?
ie 1S/1C bell from ce71 has different position of the clutch slave than say a cr30/sa60 (same side but lower down but same fork)
cheers to big_boy, ae25, mykool
