4A cranshafts, whats interchangable?
Postby ae93_sx » Wed Apr 02, 2008 11:31 am
Okay, basically i have a bigport 4agze with a stuffed crank. I purchased a 20v silvertop crank thinking that they were interchangable. My Machinist compared the 2 cranks and the 20v ones seems to have larger bigends.
So basicaly what i need to know is what version of the 4A i can pinch a crankshaft from.
alternatively, do you think the 20v one could be machined down to match? i'll contact my machinist and ask the question later today.
4agte ae92 hatch
ae93_sx
Postby Trls250s » Wed Apr 02, 2008 12:04 pm
Bigport cranks are only interchangable with bigports.
Smallport, and both 20v have the same crank dimensions.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby ae93_sx » Wed Apr 02, 2008 12:33 pm
bugger! so would an NA bigport and a GZE bigport have the same crank?
4agte ae92 hatch
ae93_sx
Postby slighty_sykotic » Wed Apr 02, 2008 12:45 pm
Trls250s wrote:Bigport cranks are only interchangable with bigports.
What?
Thats not right.
Bluetop bigport is the only different one. Redtop bigport is the same.
EVERY CRANK IS THE SAME EXPECT BLUETOP.
Tell your mechinic to check again. Unless you have a crazy 4agze butilt with 40mm journals....
slighty_sykotic
Postby ae93_sx » Wed Apr 02, 2008 12:53 pm
I thought early NA bigports were the only different version to! had a couple of people confirm that a 20v crank would suit my needs before i purchased it only to be told otherwise at the machineshop once measured
I'll give my machinist a call
4agte ae92 hatch
ae93_sx
Postby xsspeed » Wed Apr 02, 2008 2:05 pm
yeah i'm sure only bluetops run the 40mm crank
Postby ae93_sx » Wed Apr 02, 2008 3:15 pm
turns out that it was the right crankshaft. i misinterpreted the bloke. he meant the journal was too small because it had spun a main bearing and there was a fair bit of meat missing.
so now i need to find yet another crank :(
4agte ae92 hatch
ae93_sx
Postby Trls250s » Wed Apr 02, 2008 3:34 pm
Sorry i forgot there was a redtop bigport.
They are yucky so i dont even consider them.....
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Users browsing this forum: Bing [Bot] and 2 guests
