muffler
muffler
Postby metric » Thu Apr 03, 2008 9:34 pm
Anyone know where i can get one of them mufflers with the butterfly valve inside it that you can change inside the car ?
have seen a few adverts but cant seem to find any at the moment!!
metric
Postby RickGT » Thu Apr 03, 2008 10:58 pm
iirc any valve in the exhaust system is elligal, im sure i read it at ltnz
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby RickGT » Thu Apr 03, 2008 11:05 pm
"An exhaust system must not be constructed or
modifi ed in a way that allows a person to interfere
readily with its operation or reduce its eff ectiveness"
EP91 Glanza V
RickGT
Postby metric » Fri Apr 04, 2008 7:52 am
yeah yeah i guessed that one
if i wanted to be told off i would of asked my mother
so does anyone have one or know where to get one?
metric
Postby cogent » Fri Apr 04, 2008 9:25 am
RickGT wrote:"An exhaust system must not be constructed or
wonder if that applies to good ol supatrappz
cogent
Postby slighty_sykotic » Fri Apr 04, 2008 11:05 am
metric wrote:yeah yeah i guessed that one
How about a muffler shop!!!!!!!!!!! Shock horror!
slighty_sykotic
Re: muffler
Postby solitaire » Fri Apr 04, 2008 11:14 am
metric wrote:Anyone know where i can get one of them mufflers with the butterfly valve inside it that you can change inside the car ?
Whats the point?
AE92, KZJ120, KDJ120
solitaire
Postby Akane » Fri Apr 04, 2008 2:45 pm
APEX'i used to do one that's manually operated, and back in the 2003 days there was a group buy on an electronic one made by some American company.
Postby TRD_ZERO » Fri Apr 04, 2008 3:36 pm
I think its called verex muffler or something like that
TRD_ZERO
Postby MR2SIK » Fri Apr 04, 2008 4:34 pm
I was thinking about using one of them recently, and have the valve controlled by a rev switch, kinda like the Jags/Astons/New Falcons use.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Re: muffler
Postby Bling » Fri Apr 04, 2008 5:04 pm
Whats the point?
with a combination of said awesome switching butterfly illegal crap and his $79 trademe fuel chip, hes going to double his power and mileage in one foul swoop :roll:
Re: muffler
Postby solitaire » Fri Apr 04, 2008 7:25 pm
BZG|Bling wrote:with a combination of said awesome switching butterfly illegal crap and his $79 trademe fuel chip, hes going to double his power and mileage in one foul swoop :roll:
:lol:
So its just so you can have your exhaust louder than the legal limit? thats it?
solitaire
Postby Guss » Fri Apr 04, 2008 7:49 pm
you're all so skeptical, maybe he wants to have a normally quiet car 90% of the time and a mildly loud car the other 10% (which are hopefully during daylight hours ).
I think it is legal and can be certified provided it does not exceed 95db in any setting.
Guss
Postby metric » Fri Apr 04, 2008 8:08 pm
definably a day car only has only been out at night for some ball drop offs, but at the moment it has a flange just before the muffler that i swap before going racing as such.
the normal muffler is reasonably quiet but really cuts power in the 5000+ region would be nice to be able to get round this
was really lookin for the different companies/names, and anyone that has experienced what they are like
metric
Postby Bling » Fri Apr 04, 2008 9:23 pm
Guss wrote:you're all so skeptical, maybe he wants to have a normally quiet car 90% of the time and a mildly loud car the other 10% (which are hopefully during daylight hours ).
i'm not sure if its skepticism or being realistic as to his requirements and whats actually legal to do
Could be an option to get a better muffler then? loud doesn't equal power. A fast car can easily be quiet, so maybe look at a redesign of your current system. what size piping?
what car is it?
Postby Dell'Orto » Fri Apr 04, 2008 10:05 pm
BZG|Bling wrote: loud doesn't equal power.
Unless its an NA rotary, quiet exhausts choke the bejesus out of them.
Postby method » Fri Apr 04, 2008 10:47 pm
BZG|Bling wrote:loud doesn't equal power
What!?
Every one knows the louder it is the faster your car goes!
Find me a quiet car, you keep it quiet and make power, ill make it loud and have more power. :lol:
PICS UPDATED DAILY
method
Postby Bling » Fri Apr 04, 2008 11:11 pm
the more guages you have the faster you go too.... *leaves thread* :P
Postby darkwolf » Sat Apr 05, 2008 9:17 am
BZG|Bling wrote:the more guages you have the faster you go too.... *leaves thread* :P
The correct term is clocks :)
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby barryogen » Sat Apr 05, 2008 1:27 pm
The altezza's have one in their factory muffler, it is spring controlled, not sure if it is on both models or not.
Can't be bothered finding, it, but when I was reading about it I followed a link from here.
http://homepages.paradise.net.nz/jswright/altezza.html
Apparently the spring breaks after a while and rattles in the exhaust, and no way to open it up without royally $&#$% it.
There is an Aussie company that makes them too, can't think of their name off the top of my head.
You could always have a go at making one yourself... would probably need some help from a physicist/spring person and a flow person to sort out the pressures you'll be dealing with.
http://autospeed.com/cms/A_1744/article.html?popularArticle
I think it's a cool idea, personally I have been wondering about fitting a wastegate type of thing to my exhaust to keep a constant amount of back pressure to keep noise to a minimum... yeah it'll use a bit more gas having to force the exhaust out, but I'm more concerned about noise than fuel consumption... at least at the moment.
barryogen
2ZZ Guru in training
