anyone got a strut available to measure?
Postby fuel » Thu Apr 03, 2008 7:14 pm
hey guys, I need to find a pair of struts suitable for taking the threaded top off to weld to my shortened struts, which are about 55mm OD.
So I need to find struts which have a similar OD size, and has removable inserts - doesn't matter if it's front or rear.
Cheers!
LOUD NOISES!!!
fuel
Postby fangsport » Fri Apr 04, 2008 7:17 am
sounds like your looking for Celica, Cressida etc struts.
fangsport
Postby fuel » Sat Apr 05, 2008 12:27 am
Do you happen to know what the OD is on those struts?
LOUD NOISES!!!
fuel
Postby fangsport » Sat Apr 05, 2008 8:18 am
54mm from memory. will check later for you if someone else dosn't post .
fangsport
Postby d1 mule » Sat Apr 05, 2008 7:38 pm
hope this helps man, tis the best shock guide iv found
http://trdparts.jp/english/list_shock-cartridge.html
heres another that might be of some use
http://www.trdparts.jp/english/list_race_shock.html
d1 mule
Postby fangsport » Sat Apr 05, 2008 8:40 pm
fangsport wrote:54mm from memory. will check later for you if someone else dosn't post .
TA63 and Ta57 are 51mm.
may need to measure 6 cylinder supra?
fangsport
