QikStarlie wrote:i'd take it back and get damian to check the afr to be safe. also, you'd be better off with a dedicated line from manifold to the link. dont tee anything into it.
IH8TEC wrote:i run dedicated line for
link
fpr
bov
boost gauge
basically every line off my mani is a dedicated line for something, much better
lorolla24 wrote:Download the Link User manual off the website. Then you can just tune the boost control yourself and tells you everything.
I know first hand, if you have air leaks you can never get the best results especially with turbo spool. I have a 20v turbo and took me a few go's to get rid off small leaks.
18psi will eat gas,most of the time road tunes are rich mixtures anyway.(safer)
Crampy wrote:Is it worth getting the AUX plug and the proper turbo Bosch air inlet temp sensor when I order the ComLink?
Anyone on here not using an air inlet temp sensor?
matt dunn wrote:Crampy wrote:Is it worth getting the AUX plug and the proper turbo Bosch air inlet temp sensor when I order the ComLink?
I never ran one on any of my 1600 turbo motors,
even with the LEM and Linkplus that I used.
Was not till I went 7A and G3 that i got one.
Crampy wrote:matt dunn wrote:Crampy wrote:Is it worth getting the AUX plug and the proper turbo Bosch air inlet temp sensor when I order the ComLink?
Was that with your race car, or with a street car?
I can see why you might not bother with a race car, but there are a lot of things that change with a street car. Temp of the day, traffic conditions, heat soak from intercooler after a long power pull compared to a short squirt of power for passing.
flygt4 wrote:i've run no air temp sensor, no o2 sensor and no knock sensing forever on my car. seems to have held up well enough.
just get a good tune that you can rely on.
a good dyno tune will change everything, improve economy, make the powerband more linear, and most of all tidy up the transition coming onto boost.
even though the engines are good for 25psi, there no need to run high boost all the time either. 14psi should be good enough for giggles and it will do it forever.
QikStarlie wrote:will make the car a bit more consistant if setup right. but thats the thing. it needs to be setup right to be any advantage. your tuner would either have to caculate the numbers somehow, or tune the car at diffrent temp levels to do so. i'd bet alot of cars out there with a iat sensor installed, wont be being used
v5 has limited adjustment, a number that decays as temp rises. g3 is fully adjustable.
if your going to pay the extra to install and have it setup right, go for it. other wise i wouldnt bother
