aftermarket temp gauge
Postby fx gt » Tue Apr 08, 2008 8:56 pm
have a aftermarket temp gauge
but it dosnt work :(
it has power,negetive and sender hooked up
car is a ae92 4age. i have the temp sender unit on the top rad pipe close to the dizzy. when i turn the ingition on the gauge turns on but goes straight to 40.c and thats where it stays!
commen problem here or have i set it in rong place?
fx gt
Postby .:O4AGTZ:. » Tue Apr 08, 2008 10:27 pm
im pretty sure its somethin to do with the fact that from factory it reads either right temp or wrong temp, and not an actual temperature. so when you turn it on it just goes straight up. its an on or off signal
.:O4AGTZ:.
Postby .:O4AGTZ:. » Tue Apr 08, 2008 10:28 pm
im pretty sure its somethin to do with the fact that from factory it reads either right temp or wrong temp, and not an actual temperature. so when you turn it on it just goes straight up. its an on or off signal....sorry my mind is a bit dead im sure someone else will explain it in a more helpful way if that is the problem haha
.:O4AGTZ:.
Postby ollieboy » Tue Apr 08, 2008 11:16 pm
They usually earth through Temp sender so if its not right it will fugger up your reading. Also, is it an aftermarket sender too?
ollieboy
Re: aftermarket temp gauge
Postby matt dunn » Tue Apr 08, 2008 11:24 pm
fx gt wrote: i have the temp sender unit on the top rad pipe close to the dizzy.
Is it in a pipe in the middle of two rubber hoses?
Is the base of the sender or what the sender is screwed into earthed?
Postby fx gt » Tue Apr 08, 2008 11:38 pm
Is the basxe of the sender or what the sender is screwed into earthed?
first question-yes
secound question- no :P
fx gt
Postby fx gt » Tue Apr 08, 2008 11:39 pm
ollieboy wrote:They usually earth through Temp sender so if its not right it will fugger up your reading. Also, is it an aftermarket sender too?
yes its running aftermarket one
fx gt
Postby postfach » Tue Apr 08, 2008 11:43 pm
I'm gonna guess if you answer yes to matts first question you need to answer yes to question 2 for it to work properly, try earthing the body of the sender or the metal pipe thing its screwed into
postfach
Postby ollieboy » Wed Apr 09, 2008 12:01 am
Yeah, like I said above, the temp sender has to earth or it wont read right.
ollieboy
Postby fx gt » Wed Apr 09, 2008 9:42 pm
earthed metal pipe where sender goes and still does same thing, do i need to earth the gauge to the sender?
fx gt
Postby Stealer Of Souls » Mon Apr 14, 2008 7:40 pm
Are the sender and gauge a "matched pair"? I.E. Same vendor?
Most vendors will match their gauges to their senders. Assumably many senders are the same, but I suspect there are some that aren't... Can anyone else confirm?
'86 AE85.5 Levin
Stealer Of Souls
Postby fx gt » Mon Apr 14, 2008 10:19 pm
got it working sweet
i grounded it but didnt warm it up :lol: :oops:
working mint now so thanks,before i had no idea what temp it was running :roll:
fx gt
