1UZ + Hilux.
1UZ + Hilux.
Postby Silent Knight » Fri Apr 11, 2008 10:12 am
Now as it stands I think there is a slight possibility that I blew my HG this morning on the way to work. Not confirmed at this stage as I just left the flipping thing in the car park and came to work, will find out tonight when I go home...
I know there's a few folks in here that has had experience with doing this all so I want all the dirty details.
- How easy?
- What is needed?
- What's needed to keep it 4WD?
- Average cost (excluding 1UZ purchase)?
- Can I run standard computer? (I've heard the V6 computer will be able to run in synch with the 1UZ)
I need facts, not you heard this from your mum's uncle's second cousin's brother type of stuff...
Thanks!
Silent Knight
Postby Mr.Phreak » Fri Apr 11, 2008 10:56 am
Phft, you can't handle a 1UZ :P
Mr.Phreak
Postby 2LTR Rona » Fri Apr 11, 2008 11:47 am
God dam tech support people who cant use google :P
http://www.geocities.com/deonsv8hilux/
That should give a good bit of info, wont fill in all the blanks though
2002 Altezza, 1974 KE25
2LTR Rona
Postby postfach » Fri Apr 11, 2008 11:50 am
doesn't help that its "temporarily unavailable" either :P
postfach
Postby Silent Knight » Fri Apr 11, 2008 11:59 am
2LTR Rona wrote:God dam tech support people who cant use google :P
I've already seen that! :P
I don't want to read someone's life story, just straight forward this/that this/that so I know what I'm up against and what exactly I need. 1UZ to Lux has come a long way since then and most the stuff to do is available off of the shelf but I've never done it so need more info...
C'mooon, isn't there a CHCH on here somewhere that's recently done it?
Silent Knight
Postby 2LTR Rona » Fri Apr 11, 2008 12:00 pm
postfach wrote:doesn't help that its "temporarily unavailable" either :P
true ??
Oh well must be a perk working for Telecom that I can see it then :P :lol:
2LTR Rona
Re: 1UZ + Hilux.
Postby 2LTR Rona » Fri Apr 11, 2008 12:03 pm
Silent Knight wrote:- How easy?
- What is needed?
Answers
- Depends on how many drinks she has had
- Many pizza's & many beers
- A 4WD to start with doh!
- Depends on how many kids you end up with
- Nope, must use a MAC :P
**leaves thread**
2LTR Rona
Postby dskd » Fri Apr 11, 2008 6:41 pm
its not that hard to do u will get no change out of 6g
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
Postby gepsk8 » Fri Apr 11, 2008 7:41 pm
put 1/2jz into it less common, 1uz getting old done to many times.
nite b (brendan) probably man to talk to hes done it. 6g sound cheap to me!
can u do it all urself?
1-2.5g for motor (with ecu and loom that doesn't auto or go link add 2.5g+)
-cambelt, waterpump, plugs? leads? while its easy
*i would get the starter done to as it inlet manifold off job to get at.
1g flywheel and bellhousing
300-1g clutch (depend what u get)
then ur got mounts
headers
exhaust
wiring up engine (depend who u know, and what u know)
cooling fans and radiator(use standard or upgrade)
Fuel system should be fine
that what i can think of.
O272754663
gepsk8
Postby Silent Knight » Fri Apr 11, 2008 8:34 pm
gepsk8 wrote:put 1/2jz into it less common, 1uz getting old done to many times.
I'm not looking for a prize in originality, I'm looking for functionality...
Turbo conversions have been done plenty a time too going by that logic... errr :lol:
Silent Knight
Postby dskd » Fri Apr 11, 2008 8:46 pm
1uz 1000
5 speed R box 1000
computer and wirering 1800 link
cluch 700
bellhouseing R to 1uz 600
fly wheel 500
mounts 300
others 15% 800
total $6700
and you doing all the work + cirt
prices off trade me and car wreckers
dskd
Postby WCKWGN » Fri Apr 11, 2008 10:03 pm
http://www.youtube.com/watch?v=cAlfAK7jXi8
Dunedin supercharged 1uzfe hilux now at 340rwhp - video at only 4psi . Night video but you get the idea of it. All the convincing you need :lol:
WCKWGN
Postby postfach » Fri Apr 11, 2008 10:13 pm
Dammit, I want a 1UZ in something now >__< oh well, tow car project!
postfach
Postby WCKWGN » Fri Apr 11, 2008 10:41 pm
tow your trailer slideways... good old dunedin wharfs :D
WCKWGN
Postby Mr Revhead » Sat Apr 12, 2008 1:47 am
i happened to bump into TSer doing this exact conversion the other day.
I will point him in this direction if he doesnt find his own way here.
Postby Silent Knight » Sat Apr 12, 2008 2:09 pm
dskd wrote:1uz 1000
5 speed R box 1000
cluch 700
fly wheel 500
mounts 300
others 15% 800
total $6700
Luckily I can cut most of those prices out as I won't be using a manual gearbox...
Silent Knight
Postby Silent Knight » Sat Apr 12, 2008 9:20 pm
SOOOO... anyway seems I got all up in arms about something that is NOT really something because I was so damned $&#$% off at the car at that stage... :lol:
It's not actually a BHG, it's a hose under the inlet manifold right in front of the firewall that has a massive crack/leak in it. Has anyone ever pulled the inlet manifold off of a 3VZ-E before? It sorta looks like a not too hard task except for the bolts at the bottom of the manifold, are there bolts on both sides holding it on or only the open side? If there are on both sides I have no idea how to get to them without actually removing the whole friggen head... :?
Silent Knight
Postby Lloyd » Sat Apr 12, 2008 11:12 pm
Silent Knight wrote:Has anyone ever pulled the inlet manifold off of a 3VZ-E before? It sorta looks like a not too hard task except for the bolts at the bottom of the manifold
lol, gotta love how they look easy :lol:
You gotta get it off to get at the head bolts so dont think you'll be going as far as taking heads off. The ones that are worst to get at are the very back couple, but once you get the bracket or whatever it was off right at the back then you'll see a couple of nuts. Other than that it should be pretty straight forward
Postby deaf_rattle » Sun Apr 13, 2008 12:38 am
bugger it, 1uz it anyways :lol:
Postby Mr.Phreak » Sun Apr 13, 2008 12:38 am
Guess this means the Soarer might actually almost nearly kinda get to a workshop this year :lol:
Mr.Phreak
Users browsing this forum: Bing [Bot] and 22 guests
