w58 out, r154 in.. wat needs to be changed?
Postby YeMs » Tue Apr 15, 2008 6:09 pm
ok, im gunna be sussing out an r154 soon for my cressida as i dont like the chances of a w58 holding over 300kw.
so interchangeability.. input shaft splines? are they different? so would have to get clutch plate also.
i kno the r154 is pull type, but thats easily changed.
yoke sizes? will the w58 yoke fit in?, any 1 know if the boxes are the same length and mount similarly? (so i dont have to change d/shaft length)
Your local Hybrid Elite tech
YeMs
Re: w58 out, r154 in.. wat needs to be changed?
Postby Jason T » Tue Apr 15, 2008 10:36 pm
YeMs wrote:ok, im gunna be sussing out an r154 soon for my cressida as i dont like the chances of a w58 holding over 300kw.
Clutch drive plate input spline is same
Drive shaft out put is different W58 21 spline R154 23 spline
Rest of box totaly different
Look at this link http://www.4cefed.com/w58vsr154/w58vsr154.html
Fixing Toyota's since '87
Jason T
Postby Py7h0n » Wed Apr 16, 2008 12:07 pm
I would think twice about changing to Push. Pull is a great setup.
Py7h0n
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
