Drum brakes...
Drum brakes...
Postby FST4RD » Thu Apr 24, 2008 4:55 pm
Not a toyota but you guys seem to know a bit....
I have a Mazda familia BF 1987 1300cc of raw power with drummies on the back.
The back left was rubbing and it was quite hard to turn. Talked to a few people and they said it was either the bearings or the pads have grooves and so do the drums and they're catching.
So pulled it apart and the bearings were fine but the pads and the drums had grooves like and old vinal LP :x
So off to safe-r-brakes with both drums and old shoes to get the drums machined and new shoes.
Right side fitted up easy as no issues, the problematic left side though.... well heaved and hoed and with a bit of forced managed to finally get it on again! Only thing is really really hard to turn the wheel now! (i realise new shoes are thicker)
Also got told with these cars to set the drums right to drive in reverse a few times and rip on the hand brake which i did and the right side seems to be fine but the left is still dragging! Now i'm going to the coast (350KM) tomorrow and it's still dragging, apart from wearing the shoes down am I going to have any other issues? Also the handbrake light in the dash is on and doesn't turn off.... I thought the sensor was at the lever?
Thanks Guys
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby THA SHZ » Thu Apr 24, 2008 5:05 pm
did you bang it with a hammer and losen it up , make sure it moves and then adjust to suit 8)
THA SHZ
Postby FST4RD » Thu Apr 24, 2008 5:11 pm
Did a lot of banging with a hammer to try and loosen things up....
And no nothing broken or bent :lol:
FST4RD
Postby Bling » Thu Apr 24, 2008 5:16 pm
depends how tight it is i'd say, a 350km trip at high speed could generate quite a bit of heat if it doesn't ease off :?
is it the same story without the handbrake tightened?
Postby Mr Revhead » Thu Apr 24, 2008 5:18 pm
did you back that side off first?
as tha shz mentioned make sure all the adjustment bits are free.
if they are too tight you will have quit a lot of heat there....
not to mention it will kill fuel economy
Postby FST4RD » Thu Apr 24, 2008 5:18 pm
Yeah I was thinking about loosening that side off slightly.... might be worth a shot
FST4RD
Postby Lloyd » Thu Apr 24, 2008 7:28 pm
Have you actually adjusted the rear brakes at the brakes themselves, or did you just chuck on new shoes and machined drums?
Postby FST4RD » Thu Apr 24, 2008 7:58 pm
All sorted!
Everything was loosened off as much as possible.... just missed the fact that the handbrake cable had siezed and would go on but not back off....
Funny how it can take a second set of eyes to notice these things :oops:
All nice and free now :D
Thanks guys
FST4RD
Postby rollaholic » Thu Apr 24, 2008 10:58 pm
did that fix your handbrake light problem too? because that can be caused by low brake fluid also.
Postby FST4RD » Thu Apr 24, 2008 11:05 pm
Oh that was totally unrelated..... :lol:
Pulled the center consol out to adjust the hand brake cable and noticed that the switch thingee was loose, tightened and all good :D
Must have been all that banging with the hammer! :lol:
FST4RD
