Link V1 or V3 ECU Problems
Postby mr_monkey » Wed Apr 23, 2008 11:06 pm
RED UNDERPANTS!
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby RedMist » Wed Apr 23, 2008 11:35 pm
My guess, hes fried a FET.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby mr_monkey » Wed Apr 23, 2008 11:46 pm
Have you checked your fuses?
mr_monkey
Postby mr_monkey » Wed Apr 23, 2008 11:53 pm
Maybe you should have had fuses :lol:
mr_monkey
Re: Link V1 or V3 ECU Problems
Postby matt dunn » Wed Apr 23, 2008 11:55 pm
driftdays wrote:When i was looking for the problem I shorted on the ECU plug (while it was unplugged from the LINK ECU) between Constant and Earth (the High energy igniton pack was still plugged in)
If you did it while the ECU was unplugged, cant have damaged the ECU.
Does the fuel pump still run when you first turn on the car?
Yes = ok
No = blown fuse.
Postby matt dunn » Wed Apr 23, 2008 11:57 pm
also how was the igniter unit tested?
Postby matt dunn » Thu Apr 24, 2008 12:02 am
driftdays wrote:Fuel pump runs as its on a switch
Igniter was tested with multimeter?
So the fuel pump is not ECU controlled?
Cant use that to tell if the ECU is powering up then.
Cant test an igniter with a multimeter accuratly.
what sort of igniter? how many wires and what labels.
Postby RedMist » Wed Apr 30, 2008 8:19 am
How did you get on?
I still think with fuel and no spark, and the way you pulled the ECU, you're looking at FET damage.
RedMist
Postby KinLoud » Wed Apr 30, 2008 9:51 am
Description of how it kept running seems to tell me that the "kill switch" disconnected the battery but the alternator kept supplying power...
Rewire the kill switch to disconnect power going to the fuel pump and the computer so if you have a crash the kill switch will stop the pump spraying fuel onto any fire that might happen!
Ken
Ham
021 408 863
Postby mr_monkey » Wed Apr 30, 2008 10:36 pm
KinLoud wrote:Description of how it kept running seems to tell me that the "kill switch" disconnected the battery but the alternator kept supplying power...
Ken
Ham
021 408 863
Hiya ken.
Exactly what I said...........and then they went and shorted the thing out and stuffed it.. haha.
Was going nice too.
mr_monkey
Users browsing this forum: Bing [Bot] and 1 guest
