Interior questions
Postby Lloyd » Sun May 04, 2008 1:17 pm
Wire brush it until most of its gone, soak a bit of rust kill stuff on it overnight (can get it at Repco) and if you can get a bit of compressed air in the next day to make sure its dry. Can put a bit of fishoil on if you want, and if you use it or not get some of that brush on underseal stuff to keep anything out. Can use the spray on but it just doesn't go on as thick.
And the sound deadening sheets you can get, no point spending the extra money on name stuff from Repco etc that use it for car audio. There is a place that does it reasonably priced down here, can get it per sheet or in boxes of 10 from memory. Sticky on one side, lay it down and heat the crap out of it with a heat gun to mould it into place nicely
Postby xsspeed » Sun May 04, 2008 2:52 pm
id probably refrain from fish oil under the dash, cos if use your fans ur just gunna get that smell blown at ya. surface rust, depending on how coarse it is i wouldnt worry, if its a big deal to you id get some fine-ish grit sandpaper and get it off with that, failing that wire brush and rust inhibitor, though i cat see it needing that much attention.
Postby Alex B » Sun May 04, 2008 6:34 pm
I don't think Ive ever seen one of those bars that isn't rusty. Its just surface rust. Wire brush it, buy a can of hammerite and spray it. As for sound deadening, find a bostic agent and buy it from them. Dyna mat = $$$.
Just don't be over paranoid this isn't an AW11, I haven't seen one photo you have posed yet i would deem a rust issue as such.
Postby Lloyd » Sun May 04, 2008 7:09 pm
lol, stupid me thought it was an AW. If its an SW then don't worry, wire brush anything and give a flick with some spray paint.
Postby solitaire » Sun May 04, 2008 7:44 pm
Thanks for all the advice guys - Much apreciated :D
Not a very good photo but heres the dash: http://i256.photobucket.com/albums/hh19 ... G_3351.jpg
Just an fyi really in case you had anything else to add... will just leave it as per your advice unless you think i should deal to it.
Another issue is the seat mounting point, it has a fair pit of pitting there and while i have cleared it away ready to pain i am concerned that the area in the little raised section where a sander and paint cannot reach may be going nasty...
Heres the pictures, not embedded in case we have anyone on a modem. The raised hollow i mentioned is right in the middle of the image.
http://i256.photobucket.com/albums/hh192/solitairetoyspeed/IMG_3358.jpg
http://i256.photobucket.com/albums/hh192/solitairetoyspeed/IMG_3360.jpg
AE92, KZJ120, KDJ120
solitaire
Postby Lloyd » Sun May 04, 2008 9:14 pm
The word paranoid springs to mind.
Dont worry about that, its next to nothing. Wait until you buy a KP or a KE70 :lol:
Postby solitaire » Sun May 04, 2008 9:51 pm
HRT wrote:The word paranoid springs to mind.
And you would be right... i spend 80% of my life worrying about things... :lol:
Just didnt want to spend all this time doing it to have a bit of rust i couldnt get to ruin it all :wink: But cool ill just do what i can and maybe spray a bit of fish oil in there when its painted & cured
solitaire
Postby Alex B » Sun May 04, 2008 11:49 pm
You dont usually put fish oil over paint. Hammerite for the win, brush it straight over the rust.
Postby Bling » Sun May 04, 2008 11:54 pm
if you're already going to have POR15, just slap that on anything you are worried about, it will sort it.
Hammerite does look the business tho, but POR15 does the trick
Postby solitaire » Mon May 05, 2008 12:03 am
oh i thought you needed to get a good amount of the rust off first?
Perhaps im going about this all wrong, im sanding around anywhere that has rust to make sure there is nothing else hiding under the paint... is this wrong?
solitaire
Postby Mr Revhead » Mon May 05, 2008 12:32 am
nope
POR15 is good stuff, but it wont magically fix rusty bits!
remove all you can, if rust has gotten under paint you need to remove that paint.
Postby solitaire » Sun May 11, 2008 1:32 pm
HRT wrote:When you have some left over, half fill your sink up with warm water and a generous amount of dishwashing liquid mixed in, chuck a decent scoop of dry ice in
:D Hang on... do i need to do this because its good for the environement or are you trying to set me up? :lol:
solitaire
Postby rollaholic » Sun May 11, 2008 2:06 pm
yeah ideally you want to clean back enough paint that the rusty area is completely exposed and you can see shiny steel all round it.
Postby Alex B » Sun May 11, 2008 4:19 pm
Try it and see :lol:
Postby AE86less » Sun May 11, 2008 4:25 pm
I have a very funny story involving a school toilet and a large quantity of dry ice :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby mr_monkey » Sun May 11, 2008 5:18 pm
AE86less wrote:I have a very funny story involving a school toilet and a large quantity of dry ice :lol:
lol.
You can carbonate your raro with dry ice too- makes it fizzy :lol: :lol: :lol:
dont try removing the tar without dry ice IMO. Ya leave bits behind which are a pita to remove. Just chuck dry ice over it and 99% of it will come off cleanly.
I removed the tar from my sw20 using a heatgun and petrol. It was the worst job in the whole entire world and i don't recommend going that route. EVER.
I didnt even really notice the noise increase.
AW11 was different though. Couldnt even hold a conversation in that.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby solitaire » Sun May 18, 2008 8:29 pm
Dry Ice from Boc gas - 5kg's was more than enough ($30) - 2kg would do if you knew what you were doing id say :D
Thanks RomanV :D
solitaire
Postby mr_monkey » Sun May 18, 2008 8:31 pm
Is it possible to buy liquid nitrogen easily?
mr_monkey
Postby solitaire » Sun May 18, 2008 8:32 pm
mr_monkey wrote:Is it possible to buy liquid nitrogen easily?
I didnt ask but those BOC people seem to know their stuff, give them a call mate 0800 111 333
solitaire
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
