rollaholic wrote:is there any reason to keep the bluetop?
could pickup a complete smallport for 5-600 and transplant that, could save some headaches (and possibly create some more, haha)
you'll need to cut'n'shut the manifold, and fiddle round with the wiring - but if you are able to do most of it yourself i reckon you could get it running for less than $1000
which you'd make some back selling your carb engine
edit - you dont need to change fuel lines / tank etc etc. its always talked about, but my bluetop runs fine with all the old 85 lines etc in place. you just need a fuel pump is all! and an efi filter.
IKE86 wrote:If i did do a transplant can i do it with fwd and can i use that engines ecu and loom or does it have to be rwd ecu and loom.
xsspeed wrote:i was under the impression that the efi setup needed higher pressure lines than the carb'd ones
l1ttle_d3vil wrote:xsspeed wrote:i was under the impression that the efi setup needed higher pressure lines than the carb'd ones
it needs higher fuel pressure, not higher pressure lines. aslong as the lines are about 10mm for a feed and you got a return line it'll be plenty.
