adjustable actuator arms
Postby l1ttle_d3vil » Fri May 16, 2008 9:25 pm
Just wanting peoples experience on making an adjustable actuator arm; as in cutting it in half / threading it and rejoining it with threaded bar.
the turbo in question is a t25 and stock actuator runs 7psi.
would it be impossible to get 12 - 14psi- out of the same actuator with an adjustable arm?
and how reliable would it be?
-matt
Postby Crucible » Sat May 17, 2008 9:41 am
its the diaphram spring that determines the WG opening point, the arm adjustment wont make any differance.
Crucible
Real Life Mechanic
Postby l1ttle_d3vil » Sat May 17, 2008 11:10 am
yeah i understand that, but the idea is you can adjust the pressure on the spring so it opens earlier or is held shut til later. this is only what i've read on the internet though :wink: but i have seen it on a few setups too...
Postby d1 mule » Sat May 17, 2008 1:42 pm
so it changes the pre load on the actuator spring?
d1 mule
Postby escortman » Sat May 17, 2008 8:26 pm
my turbo has factory adjustable works mean
4x4 toyota blizzard offroader
escortman
Postby l1ttle_d3vil » Sun May 18, 2008 1:36 pm
escortman wrote:my turbo has factory adjustable works mean
interesting... is it based on the same idea as above? from looking at your pics in the projects section it looks similar.
how much can you adjust the boost? 1 or 2 pounds or what?
Postby escortman » Sun May 18, 2008 4:26 pm
its similar to that, the rod from actuator is threaded and the part that attatches to the gate screws onto that, yeh heaps of adjustement apprntly can go up 2 35psi, but so far controls nicely on 7 , 10 and 13psi
escortman
Postby matt dunn » Sun May 18, 2008 4:39 pm
IMO, it does work, but you may only get a limited range of adjustment,
and too much preload may cause boost spikes and unstablity.
Definatly worth a try though.
Postby l1ttle_d3vil » Sun May 18, 2008 7:41 pm
escortman wrote:its similar to that, the rod from actuator is threaded and the part that attatches to the gate screws onto that, yeh heaps of adjustement apprntly can go up 2 35psi, but so far controls nicely on 7 , 10 and 13psi
haha 35psi, mean. don't think the t25 will get that far. :(
whats the factory spring pressure? i'm not wanting to up the boost by a heap, only 5psi or so so my thinking it should be OK.
time will tell i guess :lol:
Postby escortman » Sun May 18, 2008 8:16 pm
hahaha, um not to sure maybe 6 or 7 psi, o yeh shud work fine
escortman
