3sgte in to Ae111
3sgte in to Ae111
Postby bs » Mon May 19, 2008 7:40 pm
So Im thinking about putting a 3sgte in to my trueno, as we all know they lack a bit in the power region. Im planing on keeping the engine standard for a wile, but putting in new bearings etc in wile its out. And will be keeping it FWD sadly enough.
There was a post awile ago about it in to an ae101 but I still have a few questions.
viewtopic.php?t=52684&highlight=3sgte
For a start which generation 3sgte would I be better off with using, and is there much difference between the generations.
Im guessing it would be a lot easyer to get a complete celica and jsut swap as much as I can over the get what else is needed made up to fit. And the get a FWD box from a non gt4.
Id pefere it to have the top mounted air to water intercooler so know one will know that its hidding away in there.
As said in the previous post would it be best to exactly center the engine. Would 20mm back a big difference with weight distrubation?
Any help and or advise would be muchly appreichated. Cheers
bs
Postby xsspeed » Tue May 20, 2008 2:10 pm
