matt dunn wrote:I would doubt the turbo would leak water into the oil,
and after owning a GTiR and having to pull the head off it i can honestly say,
I would have sold it as is too !!
slighty_sykotic wrote:Yeah, i've done a headgasket on my last one.
$&#$% it was horrible.
matt dunn wrote:slighty_sykotic wrote:Yeah, i've done a headgasket on my last one.
Well then, you'll know to make sure there are hose clips on the wastegate actuator line where it goes across the intercooler,
As the wategate feed falls off and they dont have a boost cut.
Akane wrote:I sit my GT28RS with no water cooling lines so you can bypass that to check if you really want to.
Si wrote:http://www.jimwolftechnology.com/customer_part_detail.asp?PartID=380
Done.
RedMist wrote:Akane wrote:I sit my GT28RS with no water cooling lines so you can bypass that to check if you really want to.
Corrected for accuracy.
slighty_sykotic wrote:Until its the head or the turbo that is causing the problem..... Then I just have a bigger and more expenisve sr20 (sr24..) covered in milky sh*t.
Akane wrote:RedMist wrote:Akane wrote:I sit my GT28RS with no water cooling lines so you can bypass that to check if you really want to.
I know, soon........... soon I might stop procastinating and do something.
~SlideWays~ wrote:Akane wrote:RedMist wrote:Akane wrote:I sit my GT28RS with no water cooling lines so you can bypass that to check if you really want to.
I ran a GT28RS with no water lines and it died after less that 10,000km's. Steve Murch's report said bearings were overheated. Most likely due to no water cooling.
Expensive lesson learnt![]()
slighty_sykotic wrote:Best idea to get watery oil sh*t out?
