Gearbox problems any views welcome
Postby trd-drifting » Mon May 19, 2008 9:03 pm
Gearbox problems once again… and suprafest is in 2 weeks :’(
I am running a w58 behind my 1jz. Have a 4 puck clutch etc… and is stock but 255rwkw apparently w58s can hold a lot more power than that stock. I have done the bearings on the lay shaft etc… at start of the year suspected bent lay shaft as replaced bearings and the bearings failed again… brought another w58 of an importer and it seems that the bearings have gone towards the back of the gearbox I haven’t pulled apart or off car yet so cannot say what bearings are stuffed. About a week before (not sure of the proper name) but the nut in the centre of the 2 piece driveshaft came loose and came off which holds on the hanger bearing through the spline. I have not touched that nut for over 2 and half years... I limped it home slowly about 15kms as it did not seem too bad. Pulled off, did back up etc... Replaced stuffed driveshaft bolts then about 200kms later as I was being a bit stupid in it I started to hear a knocking noise in the gearbox.
Just wanting people’s opinions would this have been a result of the pressure the drive shaft would have put on it when nut came off?
I am using Castrol VMX gearbox oil should I change to something better and what?
Would have bent something inside but not big enough to see it is bent and if I replace bearings again will they fail or who could I get to check out in Hamilton once apart…?
Any opinions would be appreciated I will upgrade to an r154 before end of the year.
Josh
trd-drifting
Postby matt dunn » Mon May 19, 2008 10:46 pm
Is it a factory bellhousing?
And is it a solid centre or sprung clutch?
Postby gepsk8 » Mon May 19, 2008 11:23 pm
something sounds bent or not alinged up propably
O272754663
gepsk8
Postby blackmk3 » Tue May 20, 2008 10:11 am
Ive killed multiple bearings in my w series gearboxes, people "say" they take lots of power, but im running 180rwkw and it died, in reality there 20year old gearboxes made for cars with less power and stock clutches
For a clunking rattling noise i would put my money on another bearing going
I run VMX seems ok :?
Bummer about suprafest im going :D, hopefully you can sort it..
Mk3 MA70 Supra
blackmk3
Postby barryogen » Tue May 20, 2008 11:12 am
The W5x series was behind the 3sge originally wasn't it?
Any reason why people don't use the 6spd from an Altezza?
Not as strong? or too costly?
barryogen
2ZZ Guru in training
Postby Mr.Phreak » Tue May 20, 2008 11:19 am
barryogen wrote:The W5x series was behind the 3sge originally wasn't it?
You might want to have a quick read of http://en.wikipedia.org/wiki/Toyota_W_transmission
Mr.Phreak
Postby strx7 » Tue May 20, 2008 3:43 pm
bellhousing is all part of the front casing unlike W style boxes.
A lot of what kills boxes is to do with HOW people change gears in them
Postby trd-drifting » Tue May 20, 2008 4:43 pm
Yes it is a factory 2jzge bell housing to w series gearbox as for clutch it is a 4 puk spring clutch, (not a solid centre) with a 2600 lbd pressure plate.
for things not to be lined up correctly the gearbox that has just done a bearing is a import and appears never to been opened in this country..
I have had it sugested to me that it could be my drive shaft out of ballance but you would notice that just driving down the road wouldnt you...?
I guess the box does get a bit of a hiding would it deffintly be worth the upgrade to a r154, or what else can i do to prevent this from happening again... what do other people do.. besides be nice to it.
Does everyone recommend Castrol vmx I have heard a lot about redline oils what are they like where can I buy from in Hamilton or nationally...
trd-drifting
Postby blackmk3 » Fri May 23, 2008 10:12 am
[quote="trd-drifting"][
I have had it sugested to me that it could be my drive shaft out of ballance but you would notice that just driving down the road wouldnt you...?quote]
If you drive shaft was out of balance you wouldnt hear a rattling in the gearbox it would shake and shudder under the car
When you replaced the bearings how did you put them on? i made the mistake of using a punch on mine, they wernt very tight and only took a few carefull knocks and they were in place
However the bearing lasted about 50kms before eating itself, spoke to a engineer and he was saying to never use a punch on a roller bearing. so ive got it all in bits now getting a new bearing fitted, we are going to "heat" it on this time, my guess would be pulling the box out and inspecting see if yours has done the same
If you need a hand or something before suprafest give us a shout 027 405 9662
Mk3 MA70 Supra
blackmk3
Postby trd-drifting » Sat May 24, 2008 10:39 am
I didnt put them on but that gearbox is sitting in the corner of the garage i havnt had the chance to open it again... but i had a friends dad who has been a mechanic who put them on. The gearbox that has just done them is fresh of a importer so i have 2 w58s that have done bearings at the moment, but depending what i find tomorrow when i open it and if it is just bearings i will take to work monday and put on there as we replace bearings all the time on motors and pumps etc... so i cant go wrong i hope.. at this stage i doubt i will be going to supra fest but are you taking your supra up or are you saying your gbox is in bits to..
trd-drifting
Postby postfach » Sun May 25, 2008 9:21 am
I ran redline MT-90 in my W58, seems to have looked after the box quite well as I've never had any trouble from it and I've put it through a fair bit of abuse. In saying that, I was also only running a factory clutch plate with a slightly uprated cover.
Last time I changed the oil in it I used VMX because I was low on cash and I wanted fresh oil in for a track day, when I drained it on friday there seemed to be more brass from the synchros around the drain plug than when I had used the redline. Whether or not that relates to the oil, or a change in my driving style that I haven't noticed, I don't know.
postfach
Postby mjrstar » Sun May 25, 2008 7:34 pm
I'm just trying to picture this in my head, but does the input shaft of the gerarbox solt in to a hole in the crank? if so maybe this isn't running true which would put a side loading on the input shaft bearing.
I run a w series box behind my 245kw 1g in the starlet and it seems to be holding up fine. but i don't have the need to do clutch kicks etc.. so i am pretty nice to the gearbox, even at the track...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby MRDRFT » Sun May 25, 2008 10:56 pm
i use the VMX oil in my supra,i have a w57 in my drift car,havent had any problems with it yet,i have blowen up a w57 once when i first got the car but not since i used the vmx oil,seems to be fine in my gearbox and thats behind a 1jz with 210kw atw.and gets a fair bit of abuse.i do have a w58 sitting in the garage incase i do pop one tho haha
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby blackmk3 » Mon May 26, 2008 1:17 pm
Yeah mines all going, replaced the faulty bearing and put the box back in, ill be going if i get a WOF tommorow
Goodluck with the bearing replacement today!
Mk3 MA70 Supra
blackmk3
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
