Gear puller - where to get one?
Postby pc » Tue May 20, 2008 1:38 pm
Does anyone know where to buy a flat legged gear puller in Wellington?
I am looking for something similar to the first one in this product catalogue
http://www.ricrova.hu/info/Bahco/pdf/Bahco_11.pdf
This is to get the 5th gear off a C52.
The pullers that Supercheap & Repco have are all too big.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Sick Puppy » Tue May 20, 2008 1:57 pm
Have you tried Engineering Supplies in Petone?
Project thread here
Discussion thread here
Sick Puppy
Postby toymato » Tue May 20, 2008 10:42 pm
I have a 3-legged gear puller you can borrow if it's what you want. Some parts of it are flat. :?
toymato
Postby toymato » Tue May 20, 2008 10:43 pm
Trade Tools?
toymato
Postby DexGT » Wed May 21, 2008 12:12 am
I may have one at work , give me a call on 027-368-6131 and come see if it will do the job .
Webster
DexGT
Postby pc » Fri May 23, 2008 4:16 pm
Tried a few options, all suck. :(
I asked a guy at Miles Udy what they do and he said they made a gear puller for getting the 5th gears off corolla boxes, and it exerts a stupid amount of force to get the gear off.
Does anyone have a method that can be used at home that doesn't break things?
red car
Manfield - 1:24s
pc
Postby 2LTR Rona » Fri May 23, 2008 6:55 pm
Pete any chance of pressing it off with a press rather than using a gear puller?
i hanvent seen the internals of a FWD box so can only comment on how I did the T50 in the KE.
Used above method with metal plates under gear / bearing etc that I wanted to remove and worked well.
Obviously you have to have access to a press etc
2002 Altezza, 1974 KE25
2LTR Rona
Postby pc » Sat May 24, 2008 8:33 pm
Dunno about pressing it off. I guess the key problem is holding the gear or getting under it so to speak. If that can be done without breaking things, then a "puller" or a "pusher" will work.
red car
Manfield - 1:24s
pc
Postby crispy'86 » Sun May 25, 2008 3:14 pm
best way i could pull the 5th gear off my c52's was to grind the legs of the puller flat on the bottom and tap into place under the gear. Then large pair of slip jaw pliers to hold the legs inwards when undoing the gear. It is a bit of a mongrel but tou can do it. Puller i used was a 2 leg type about 250mm long
crispy'86
Postby pc » Sun May 25, 2008 11:50 pm
Sounds like a good option. I did consider buying a 3 legged puller and grinding the legs flat... hopefully wont make the legs too weak.
red car
Manfield - 1:24s
pc
Postby Loudtoy » Fri Jun 06, 2008 10:31 pm
pc wrote:Sounds like a good option. I did consider buying a 3 legged puller and grinding the legs flat... hopefully wont make the legs too weak.
You tried a bearing place??
Grinding the flat bits should be ok so long as you don't go extreme.
Can i ask what you did to make pulling said part out nescessary? Something to do with a stripped 4th gear set by any chance??
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby pc » Sat Jun 07, 2008 12:35 am
My mate has a a gearbox with the 5th popping out problem... replacing the syncro shift ring thingie is easy, but I will need the toothed ring thingie (I gotta learn the names of these parts) attached to 5th gear also, which means pulling the gear off. So I need a tool that I can take to Pick-a-Part and use on a gearbox up there.
Taking a gearbox into a tool shop to find the right tool is now impossible as the only spare junk 5 speed box I had, I have already pulled apart with mad hammer/crowbar/propane torch action, so I now know how tight these things are put together, but haven't got one to practice on any more.
red car
Manfield - 1:24s
pc
Return to Wellington / Lower North Island Region
