sergei wrote:For people who need more than 300kms (which is possible to have right now with current battery tech.)
How many KW can you get with that 300km range?
there is an option of either battery swap station
Is that really practical with current battery technology???
It's not like there is just one battery and they are not exactelt easy to get at is most vehicles due to the face they take up almost all of the available space.
or back up generator trailer and yes, it will have to run on something, but think about it it has to be about 20kW tops, and can run say on McDonald's oil or methanol/LPG whatever more efficiently then normal ICE as it runs only in narrow rpm range where it is most efficient, it can even be a small gas turbine (40-50% efficiency vs 20% for piston tech.) or a methanol/methane/hydrogen fuel cell,
Why put it on a trailer???
Surely what you describe is a hybrid car without the benefits.
or another option "15 min" recharge station just like current petrol station with beefy 100A charger.
15min recharge!!! What battery technology are you planning on using, certainly not any of the current commercially avaiable Lithium cells, their minimum recharge time is 1 hour, and even then they need time to cool down before and after charging, so their turn around time is around 2 hours. Lead acid wouldn't take that charge rate either, so you're left with NiCd or NiMH.
Even at 100amps you're limited to a very low Kw motor assuming 300km takes 3.5 hours, with a 90% efficient motor you'd need to be running 350v @400amp.hrs to run a 40kw motor for that long. So even if you used 10a/h NiMHs you'd need 12,000 of them. They'd have a total combined weight of over 2 tonnes and take up 2.5m3 of space. Even ignoring the retail cost of $300,000, is that't really a practical long distance car?
Honestly I don't think current commercially available battery technology will work when it come to fast recharging. There were some experimental Lithium batteries that promised a 1 min charge time, but the cost was astronomical and the life was very limited. Even if you could find a battery with a short enough charge time the voltage and current requirements make it a very dangerous propsition.
