Beams 3SGE - turbo questions.
Postby Boosted_162 » Wed May 28, 2008 8:51 pm
Hey,
Im just starting to spend money on on my SW20. Now my current engines definately gunna need some work (bearings need changed, and is probably needs a freshen up. has done 200k). Now ive been tempted by Markku's (ex Daves) Beams 3SGE. What is the availability of aftermarket parts to turbo these motors? Forged pistons/rods/headgaskets etc? Im gunna be using a larger turbo, hoping to make about 400hp i guess.
And im guessing i wont be able to use my 93+ 3SGTE PowerFC?
Postby d1 mule » Wed May 28, 2008 10:26 pm
would it not be easier and cheaper to buy a factory turbo motor do a few bolt ons and your away maybe not 400 hp without cracking it open but not too far off??
d1 mule
Postby Boosted_162 » Wed May 28, 2008 10:28 pm
d1 mule wrote:would it not be easier and cheaper to buy a factory turbo motor do a few bolt ons and your away maybe not 400 hp without cracking it open but not too far off??
I already have a gen 3 3SGTE, im just thinking of doing something different since mine needs work anyway.
Postby Dell'Orto » Wed May 28, 2008 11:20 pm
All the 3SGTE rods and pistons should work fine, oughtnt be valve clearance issues with the lower comp pistons.
Postby xsspeed » Wed May 28, 2008 11:58 pm
I've been thinking about this for the mrs caldina wagon, I'm a long way off doing it yet but i would imagine that the parts available would be quite common, what with plenty of aftermarket 3sgte stuff kicking around and plenty of beams altezzas getting the treatment iirc.
Postby RomanV » Thu May 29, 2008 12:22 am
Postby xsspeed » Thu May 29, 2008 10:07 am
thats a pretty good read
