xsspeed wrote:nah cos then you'd have air con in your car, building services whut!
thanks tho bro, I get that, apart from the timing bit, but I can work that out. so its basically just burning more fuel on exhaust stroke to keep the turbo spinning, I assume this feature if properly controlled shuts off at higher rpm?
barryogen wrote:Is this sort of system used in other motorsport? or just rallying?
Users browsing this forum: Bing [Bot] and 23 guests
