which sparkplug?
which sparkplug?
Postby escortman » Wed May 28, 2008 11:14 pm
can someone please give me advice on what spark plugs i should get for my car?
4x4 toyota blizzard offroader
escortman
Postby Dell'Orto » Wed May 28, 2008 11:17 pm
These ones here: http://kalecoauto.com/index.php?main_pa ... ducts_id=5
But in all seriousness, you've got a smallport head now eh? How much boost are you planning on running?
Postby escortman » Wed May 28, 2008 11:25 pm
Dell'Orto wrote:These ones here: http://kalecoauto.com/index.php?main_pa ... ducts_id=5
yeh smallport now, um over 20ish i guess, aiming for around 200kw atw
escortman
Postby Dell'Orto » Wed May 28, 2008 11:27 pm
I think they take a BCPR6ES stock, so with big boost I'd be inclined to drop it to an 8 heat range. Maybe ask Brendon and Barry etc what plugs they're running.
Postby ~SlideWays~ » Thu May 29, 2008 10:12 am
Dell'Orto wrote:I think they take a BCPR6ES stock, so with big boost I'd be inclined to drop it to an 8 heat range. Maybe ask Brendon and Barry etc what plugs they're running.
From memory thats exactly what I run (8's) but had to gap them. Originally ran 6's but even on old 13psi 150kw setup it misfired on high boost (in real world conditions vs dyno).
$5 plugs FTW :lol:
~SlideWays~
Postby escortman » Thu May 29, 2008 7:21 pm
ended up gettin 7s, callum at appco said that would be sweet as thats what he runs in his starlet and its fine
so yeh
$2 plugs FTW haha
escortman
Postby flygt4 » Thu May 29, 2008 7:33 pm
andre at speedtech used NGK 8's when he tuned mine, was tuning at around 20-22psi too.
flygt4
Postby IH8TEC » Thu May 29, 2008 8:16 pm
i use BCR8ES or can't remember the new ones i have.
for over 18psi i'd go with an 8 to be on the safe side.
Postby bluemaumau » Thu May 29, 2008 8:52 pm
i tried so many places for 8s, best i could get was 7's algood, ill just get the base and run it in, then get some 8s
Postby IH8TEC » Thu May 29, 2008 8:55 pm
the otherone i use now is a R5671a-8, got them from partsmaster in henderson. when i got them i got the last 12 in stock in nz, had to come from chch. but they were getting more in,
Postby escortman » Thu May 29, 2008 10:35 pm
yeh these are only until i get the tune, i think he said something about having to get 8s in so il order them soon, not to woried if cant go over 18psi, im not sure how well the internal wastegate is going to work so may have to get external also before tune
escortman
Postby tsoob » Thu May 29, 2008 11:20 pm
escortman wrote:yeh these are only until i get the tune, i think he said something about having to get 8s in so il order them soon, not to woried if cant go over 18psi, im not sure how well the internal wastegate is going to work so may have to get external also before tune
good plan, dont wanna waste money tuning twice.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
