help: 3sgte boost / "hesitation" at multiple point
what a relief
Postby tsenior » Wed Mar 01, 2006 2:43 pm
well was talking to warrick today and he conviced me to disconnect the gizzmo and run completly stock, which i have done.. so paranoid now about knock with these engines running on 95 (no 98 here) Took it for a little blast and no bucking. I can get the Gizzmo to work with gain turned down but boost is slow , but fun when gain was at 90 boost is crazy rapid but lots of bucking. So Back to standard it is,sounds a lot safer to run these engines like this.
oh i never took the rest of the plugs out just the one i was testing..
tsenior
Re: what a relief
Postby matt dunn » Wed Mar 01, 2006 8:06 pm
tsenior wrote: but fun when gain was at 90 boost is crazy rapid but lots of bucking.
That sentence to me says Boost cut.???
Re: Pistons
Postby TWSTD » Thu Mar 02, 2006 12:42 pm
tsenior wrote:New Font TRD Bumper wich doesnt fit any intercooler, so cheap brand new 450x300 autobarn intercooler up for sale as im getting custom made 600x160x90 one built
We can suplpy an off the shelf 520x160x65 intercooler if you need it (a lot cheaper than a custom made job). Email us if you want more info.
Cheers,
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby tsenior » Fri Mar 03, 2006 8:41 pm
na no boost cut, that doesnt come on to about 20 psi and that feels quite harsh when it does go on boost cut, just gizzmo with gain set to max does not control the boost vey well even if boost set to say 11 psi, spikes all over the show.
hey thanks for the offer but i wanted 90mm or even 100mm depth to try and keep the dimensions similar to 450x300x76, but hey just sell me your bumper :) lol
Hey thanks to fivebob for the help and all the great input into this forum!
tsenior
Postby MR2SIK » Tue Jun 03, 2008 5:50 pm
sorry to dredge up an ancient thread, but I was referred to it as my gen3 3s is having the same hesitation problem.
but reading back on the gizzmo ebc and its gain feature, if you actually read the instructions, it tells you that the higher the gain, the later the solenoid actually starts working to control boost levels, meaning quicker spool, but less time to stop it overshooting the level you set.
no wonder why it was unstable setting it for 90%, I never had mine set above 50%.
And I did get mine working reliably for a couple of months, It was the shitty build quality that crapped out just after warranty that stopped me using it.
Im guessing the guy that had it doesnt frequent theses forums now, dont recognise the name :lol:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby gttNICK » Sun Jun 08, 2008 10:06 pm
I'm struggling getting my EBC set up. If I have gain over 20-25% I get boost spikes. So I run it on 15% and have the wastegate start to open at 6.5 psi before the target boost (13.5 psi). But even on that it shoots up to 14-15 psi before it drops down to 10 and then takes forever to reach the target. I tried turning everything effectively to zero (0% gain, wastegate start to open at 10psi before target) and it still spiked above the target, just not as much. This is a new controller, recently installed.
When accelerating at less than full throttle the boost comes on and off, ie, hits 8psi then drops down to 3-4psi then climbs again and repeats (watching the guage). But under full load, its ok.
How the hell do I get this thing to run steadily?
Caldina gt-t
gttNICK
