3sgte hesitating
3sgte hesitating
Postby MR2SIK » Mon Jun 02, 2008 9:03 pm
This is something that really only showed itself while racing at the drags,
but when driving kinda hard, my car hesitates for a second or so when I change from 2nd to 3rd, kind of like its hitting a limiter of some sort, at first I thought it was hitting a boost/fuel type cut, but it does it before boost builds up that high.
I really dont know how to describe it any better, just flooring it in 2nd then quickly shifting to 3rd leads to it losing all power for a bit, lifting off the accelerator then putting it down a bit more gradually seems to sort it, but that doesnt really help with my times at the track :lol:
could it be ignition related?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby DeeCee » Mon Jun 02, 2008 11:51 pm
viewtopic.php?t=23521
maybe this could help?
GT Four Adovansu
DeeCee
Postby MR2SIK » Tue Jun 03, 2008 5:59 pm
sounds exactly the same :D
ok new question, any recommendation for sparkplugs for a tickled 3s running 16-17psi? Ive been recommended a couple, providing ones that fit 4a engines do the job in the 3s too.
Sparkplugs are a completly new thing performance wise for me :oops:
Ive never had an engine that had no issues with standard issue equipment til this one :lol:
MR2SIK
Postby Dell'Orto » Tue Jun 03, 2008 6:58 pm
What are you running now? BP7ES's work sweet.
Postby MR2SIK » Tue Jun 03, 2008 7:22 pm
If I could find all my receipts I'd be able to tell ya, but Im pretty sure It was just factory spec equivilents, basicly the same as the builder put in originally.
Will pull them out next time im at my olds to double check, my tools dont reach that far into my engine :lol:
MR2SIK
Postby MR2SIK » Mon Jun 09, 2008 3:14 pm
I got BKR6EP's in there at the moment, with a number 8 under them,
as I said, sparkplug numbers etc mean nothing to me, whats that mean?
edit: They are oem fitted to the gen3 3s,
MR2SIK
Postby IH8TEC » Mon Jun 09, 2008 4:57 pm
too hot, go for some 7's or even 8's, 8's will need to be tuned for ideally at idle so it doesn't foul them up.
Postby IH8TEC » Mon Jun 09, 2008 5:09 pm
Dell'Orto wrote:What are you running now? BP7ES's work sweet.
thought your meant to have resistor plugs for links
Postby Dell'Orto » Mon Jun 09, 2008 6:41 pm
Do they not have any shielding against radio interference?
