20v block + 16v head?
Postby Pagez » Tue Jun 03, 2008 9:29 pm
so i bought a 20v to replace the 3au in my ae85, ran into the firewall + dizzy issue. Since im not keen on hacking the firewall and i dont have the coin to fork out for aftermarket computer and coil setup I have started thinking...
Does a 16v head (and rwd intake) fit onto a 20v block?
Im not sure what 16v would work so im open to suggestions - easiest is usually the best though.
So even if that is possible what about the computer? Would I need to run a 16v or would the 20v computer work fine?
And then what about the Air Sensor? the 20v I have is off a 101 so its AFM from memory...
Any help here would be magic. I have googled and searched here but when 99 pages of results come up the first 20 pages forced me to here.
Money, Power, Reliability... Pick 2 :)
Pagez
Postby Mike- » Tue Jun 03, 2008 9:55 pm
searched and found these things
viewtopic.php?t=51428&highlight=
viewtopic.php?t=47082&highlight=20v+block+16v+head
viewtopic.php?t=38964&highlight=20v+block+16v+head
when you search youve got to use 'and'
i searched for "20v block and 16v head"
Mike-
Postby Pagez » Tue Jun 03, 2008 10:02 pm
hmm, i should have read the search instructions better.
thanks mike!
ill sit back and wait for the noob flaming while i do some better searches :P :P :P
Pagez
