Motec on a ST202 3SGE BEAMS
Postby Wolf_Tm250 » Thu Jun 05, 2008 9:00 pm
RomanV wrote:There are a few alternatives to M400.
You could buy a brashboy powerfc, which is more or less plug and play... And comes with a good base tune.
Or use a 1ZZFE powerfc, has the same pinout with the exception of how coil pack return signal works IIRC, so need 2 or 3 wires spliced together and a set of 1ZZFE coilpacks. One guy was running beams 3S on standard 1ZZFE computer. Not well though :lol:
more info here on that.
Powerfc is probably the cheapest option that retains full functionality of standard computer, eg idle control, VVTI map, etc.
I'd probably rather an M400 if I plucked $100 bills from a money tree for a living though.
Very interesting... I'll tell him !
Thanks.
Wolf_Tm250
Wolf_Tm250
