help me get my 4agte runing!!
Postby Bazda » Sat Jun 07, 2008 12:20 am
those 2 extra pipes on the TB are for the PS. If you look down by the rack you will see this fitting with 2 pipes. Im sure it controls the idle up when you use full lock.
Postby themaleman » Sat Jun 07, 2008 3:55 pm
yea i know bout the ps idle up, the tb im using dosnt have the 2 outles tho so its not hooked up
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Sat Jun 07, 2008 7:33 pm
u sure that outlet for the ps hasnt come of
after puttin the smallport head on i went for a boost and came back it idling rough as and it turned out the large outlet pipe under the powersteer outlets had come out
4x4 toyota blizzard offroader
escortman
Postby themaleman » Sat Jun 07, 2008 9:28 pm
the tb im using came out of a car that didnt have power stearing
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Sun Jun 08, 2008 12:48 pm
ook sweet as then haha
escortman
Postby themaleman » Sun Jun 08, 2008 1:27 pm
can anyone tell me what the EGR dose?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Sun Jun 08, 2008 4:04 pm
themaleman wrote:can anyone tell me what the EGR dose?
Injects or allows gas from the exhaust back into the intake manifold under certain conditions to reduce combustion temperatures and reduce emissions,
i think from memory.
Postby rollaholic » Sun Jun 08, 2008 8:15 pm
pretty much on the money matt
specifically helps reduce the formation of oxides of nitrogen, which increases as combustion temp rises.
Postby themaleman » Sun Jun 08, 2008 10:47 pm
so i should use it if its there?
if i use it all i need to know is if i can use just the 1 outlet from the tb and connect both pipes coming from the egr canister to it.
responces please
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Sun Jun 08, 2008 11:44 pm
themaleman wrote:so i should use it if its there?
responces please
Sounds like you have no idea what EGR is.
Do you have a big pipe running from the exhaust manifold around to a large valve, ( about 3/4 size of an external wastegate and looks the same)
on the inlet manifold?
No?
Then you dont have EGR.
Sounds to me like you are talking about the charcoal cannister, which is
for fuel tank ventilation.
Postby method » Mon Jun 09, 2008 12:40 am
Its all economy and emissions stuff, you dont need it!
EGR - Exhaust Gas Recirculation.. does as the name suggests.
If you have modded it with a turbo you will have already biffed most of the EGR stuff. Its not gunna hurt if you biff the rest...
PICS UPDATED DAILY
method
Postby themaleman » Mon Jun 09, 2008 6:58 pm
your right i have no idea what egr is (thats y i asked).
and y dose my car have the things in the digram then?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby rollaholic » Mon Jun 09, 2008 7:28 pm
matt explained EGR a couple of posts up.
it has it in the sticker cos toyota was too cheap to make stickers for different markets? (my guess)
same reason the SC levins / truenos have upside down writing on cam covers
Postby Calvin » Mon Jun 09, 2008 10:28 pm
rollaholic wrote:same reason the SC levins / truenos have upside down writing on cam covers
Haha, this always got me. Im assuming that they couldnt be bothered changing it from the original 1st gen 4AGZE which appeared to be the correct way up in the AW11
Crazyy
Calvin
