hot off the dyno..
hot off the dyno..
Postby tsoob » Tue Jun 10, 2008 11:12 pm
255kw At the wheels tonight, with a stinkload more drivability, ready for taupo this weekend.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby method » Tue Jun 10, 2008 11:19 pm
Looks nice!
Can we have a rundown on specs? Love that shape/colour bmw.. even if they are common with a nice set of wheels i think they have class.
PICS UPDATED DAILY
method
Postby stalker » Tue Jun 10, 2008 11:34 pm
wicked!! nice figures!
Whats in it???
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby AE86less » Tue Jun 10, 2008 11:45 pm
RB30 I think. It's soo sick 8)
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby bluemaumau » Wed Jun 11, 2008 12:40 am
shouldnt rb30s be pushing past 300?
Postby postfach » Wed Jun 11, 2008 12:45 am
I see you found a home for the fully machined .coms, looks hot on that, are those 9s?? Why do they fit so well??!
postfach
Postby escortman » Wed Jun 11, 2008 7:34 am
bluemaumau wrote:shouldnt rb30s be pushing past 300?
yeh most of the 30s on about 10-12 psi seem to hit the 300 mark
maybe its a 25 or even a ..... 20
4x4 toyota blizzard offroader
escortman
Postby postfach » Wed Jun 11, 2008 9:50 am
Definitely not a 20. Maybe it only has a small turbo? Still gonna do mean skids, those chassis are pretty light IIRC.
postfach
Postby tsoob » Wed Jun 11, 2008 10:40 am
its a na25 head and 30 block, it has a garett t3/t4, shit wastegate, bov 750cc inj 2x bosch pumps, haltech ecu, after a few hours on the dyno we came to the conclusion that the stainless manifold cant flow enough and the w/g setup is not really ideal,
however 255kw wheels in a bmw is pretty loose.
They are 9's on the rear alex, it has had the full stainless pipe treatment on the guards, remember that the offset on these wheels is +15 so they fit pretty much anything, ill try and get them on my rolla for some fun later.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Lith » Wed Jun 11, 2008 11:51 am
Nice that should be a scary ride :) I can't see how a stainless manifold should restrict it to 300rwkw, considering you can make more than that on the stock cast manifold without too much problem. What type of T3/T4 is it (trim etc)? And how much boost are you running?
10-12psi is still low for 300kw from an RB30 unless its running big cams or if its on a very very happy dyno.
2007 Mazdaspeed Axela
Lith
Postby samlloyd » Wed Jun 11, 2008 6:43 pm
Ive got the same setup tsoob, but my little shitty t3/t4 limits it to around 230. :cry:
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby cat007 » Wed Jun 11, 2008 7:28 pm
How little is little?
Postby postfach » Wed Jun 11, 2008 8:33 pm
I saw this car in the flesh today, damn, its hot. The stretch on the rears is something to behold.
postfach
Postby samlloyd » Wed Jun 11, 2008 9:40 pm
.63 exhaust housing, .50 compressor i think.
I dont really know much about turbos, just trying to learn a bit these days
samlloyd
Postby cat007 » Wed Jun 11, 2008 9:52 pm
its just I have a T3 based turbo and concerned about its flow limit. Hopefully it'll do 400rwhp before pumping hot air.
Do you know what the size of the compressor wheel is?
Postby escortman » Wed Jun 11, 2008 10:10 pm
i assume u guys mean t04es? t3/4 are the flanges :wink: but yeh thats will be the limiting factor, dude at work has same engien etc with link and a master power t70 i think just over 300kw atw on 11psi
escortman
Postby cat007 » Wed Jun 11, 2008 10:21 pm
well t3/t4 are very different as far as flanges go. I have a T3 hot side and T4 cold side :)
Postby samlloyd » Thu Jun 12, 2008 8:22 am
Ill get the car back soon, ill let you know what the drivability is like. Wouldnt mind a t70 on it :)
samlloyd
Postby Lith » Thu Jun 12, 2008 9:24 am
escortman wrote:i assume u guys mean t04es? t3/4 are the flanges :wink: but yeh thats will be the limiting factor, dude at work has same engien etc with link and a master power t70 i think just over 300kw atw on 11psi
T3/T4 actually refers to the fact its a hybrid of wheels - not flanges. Most Garrett naming bases on which turbine wheel then compressor wheel family is being used, so with a T3/T4 (which is overly vague) you have a T3 turbine wheel of some sort and a T4 compressor wheel of some sort whacked together in some set of housings. Could be a 50a/r compressor cover and .63a/r turbine housing, could be anything which can be made to fit.
Maxing out below 260rwkw must be a pretty small T3/T4, though one of my mates had a Steve Murch built T3/T4 (not a random nasty) max out by 250rwkw at 18psi on his RB30. Pulled that off and put on a GT3582R and with a bit of tune fiddling it put out over 300kw on the same boost, albeit a little more lag.
Lith
Postby strx7 » Thu Jun 12, 2008 9:47 am
depends on the exact spec a T3/T4 could max out anywhere between 200HP and 450+hp (at the engine) all depends on housing A/R, wheel trims etc etc etc
Users browsing this forum: No registered users and 37 guests
