Steering arm angle
Postby xsspeed » Sat Jun 14, 2008 7:26 pm
HRT wrote:You cant put a taper in backwards
Are they tapered though? If they are how does the nut screw on, or is it just tapered up to where the thread comes out
Postby Lloyd » Sat Jun 14, 2008 7:40 pm
I'm yet to see one that isn't tapered. And yes they taper up and then have thread coming out from the top of the taper
The rubber usually covers the taper on the new ones, but you can see where it ends and the thread starts
Postby xsspeed » Sat Jun 14, 2008 7:42 pm
Makes sense, just never noticed, :oops:
Postby AE86less » Sat Jun 14, 2008 9:27 pm
xsspeed wrote:Makes sense, just never noticed, :oops:
It's why you need a hammer to get them out.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby rollaholic » Sat Jun 14, 2008 11:05 pm
maybe a hammer will put it back in from the wrong side? :P
Postby soopachargen » Sun Jun 15, 2008 5:47 pm
if you were to slam it with normal geometry you end up with the tie-rods pointing upward... will it tidy up with some load on the wheel and any lowering you may have planned?
When in doubt, down and out.
soopachargen
Postby drftnmaz » Mon Jun 16, 2008 5:22 pm
i dont think it will handle the best but you could lower it and then get a sort of RCA made to sit hub up further but arm down but would still need to be dropped on the ground :lol:
drftnmaz
Postby AE86less » Tue Jun 17, 2008 12:15 am
drftnmaz wrote:i dont think it will handle the best but you could lower it and then get a sort of RCA made to sit hub up further but arm down but would still need to be dropped on the ground :lol:
I'd really love to own a slammed AE82, but to get more than a block from my house involves negotiating some vicious bumps :(
I'm just going for the 5x100 celica hubs - Bigger brakes and less hassle, if the studd pattern pisses me off I can just fix it later. I just really want to get it running before I start fiddling with details.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Tue Jun 17, 2008 10:01 am
and you can give me your 4x100 wheels (uses the force)
Postby AE86less » Tue Jun 17, 2008 11:03 am
PM'd 8)
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby soopachargen » Tue Jun 17, 2008 2:02 pm
are you able to just change the "stub axle" bit with the studs on it over for a 4x100 one that uses the same bearings?
soopachargen
Postby AE86less » Tue Jun 17, 2008 2:26 pm
I looked at that but I couldn't figure out how to get it apart :oops:
I don't really mind anymore. I can always sort it later if it really bothers me.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
