Homemade Immobiliser
Postby FST4RD » Fri Jun 13, 2008 8:49 pm
My brother had an old early 80's carby civic 1300cc....
When he bought it it had a home made immobiliser, if you had the ciggy lighter pushed in the car started perfectly fine. If it was popped out or removed the car would turn over as if you were trying to start it but it wouldn't actually start. Bit crafty.
Which wire would you intercept and put a switch on to do this?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby rollaholic » Fri Jun 13, 2008 9:03 pm
i'd say fuel pump relay, but on a carby vehicle it would need to be spark related, probably 12v feed to coil.
Postby FST4RD » Fri Jun 13, 2008 9:13 pm
Thats what I thought....
FST4RD
Postby Voyeur » Sat Jun 14, 2008 8:23 pm
unless the guts was taken out of the lighter, it would more likely be the earth to the coil, otherwise the resistance of the lighter, wouldn't allow enough current through for the coil.
2005 vz ss commodore
Voyeur
Postby rollaholic » Sat Jun 14, 2008 9:23 pm
i presumed he was asking how you would make something similar, not how the original idea worked :D
Postby Mr.Phreak » Sat Jun 14, 2008 9:40 pm
I imagine he was going to do it properly and switch it through a relay anyway
Mr.Phreak
Postby method » Sat Jun 14, 2008 10:02 pm
Did the car stop when the ciggy lighter popped out :lol: :lol:
PICS UPDATED DAILY
method
