matt dunn wrote:You are not meant to solder oxy sensor wire, but crimp joins are ok,
and the wire they are made of is a PITA to solder anyway.
matt dunn wrote:Oxy sensors work on such small voltage that the resistance in a solder joint, (and there is) can affect the accuracy.
In reality probably bugger all,
but the correct and approved way is crimps,
if you read the instructions that come with new sensors it says soldering is a no-no, and also some sensors breath through the cable and you can put them out of sensitivity.
rollaholic wrote:i was under the impression that the O2 sensor wire was shielded too, this being the main reason for not adding random lengths of unshielded cable.
sergei wrote:2) Solder is no way resistive, I would say that crimps are a lot worse, for one when you crimp the layer of oxide remains and acts as small insulator, crimp generally tends to get even more oxydised, and finally crimp is not as strong as solder joint.
matt dunn wrote:if you read the instructions that come with new sensors it says soldering is a no-no
Dell'Orto wrote:matt dunn wrote:if you read the instructions that come with new sensors it says soldering is a no-no
I guess the manufacturers of the item don't know what to do huh? Every O2 sensor I've seen says to crimp, not solder. Gotta be a reason for that.
sergei wrote:IMO the reason of not soldering the Oxygen wires is because sensor itself heats up substantially that it is enable to transfer the heat through wire to solder joint in amounts enough to bring temperatures close to melting point of such solder making the whole connection unreliable. This is why I said it is ok to solder from the loom side.
HRT wrote:sergei wrote:IMO the reason of not soldering the Oxygen wires is because sensor itself heats up substantially that it is enable to transfer the heat through wire to solder joint in amounts enough to bring temperatures close to melting point of such solder making the whole connection unreliable. This is why I said it is ok to solder from the loom side.
There is nowhere near enough heat getting to any wiring to cause that. If anything the insulation is going to melt before that anyway
Burning Angel wrote:the reason why crimps are always used in automotive wiring is that soldered joints break if they are flexed.
Calvin wrote:Burning Angel wrote:the reason why crimps are always used in automotive wiring is that soldered joints break if they are flexed.
Also vibrations can crack dry solder joints. I was always under the impression that crimps were better in auto electrician applications
My father, an ex radio and tv repair agent goes one step furthur and recommends crimping and then soldering
Users browsing this forum: Bing [Bot] and 19 guests
