4age throttle body
4age throttle body
Postby IKE86 » Thu Jun 19, 2008 5:29 pm
Do i need to keep the coolant pipes going into this and if i do what are they actualy doing.
84 Trueno ae85:current
AE92 levin:past
IKE86
Postby strx7 » Thu Jun 19, 2008 11:16 pm
they are what controls your cold engine idle up and lessen the amount of air bypassing the TB at idle as the engine gets warmer
Postby jondee86 » Fri Jun 20, 2008 9:17 pm
You can get away without the coolant connections to the throttle
body so long as you block off the idle-up valve. If you don't block
it off the valve will stay open, and you will idle at 2000 rpm :lol:
Take the valve apart and fill it with epoxy, or better still, chuck the
valve away and close the bottom of the throttle body off with a
piece of 5mm ally plate (use some instant gasket to make sure
it is airtight).
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby IKE86 » Fri Jun 20, 2008 11:11 pm
Sweet thats what i wanted to hear.
AE92 levin:past
IKE86
Postby ChaosAD » Sat Jun 21, 2008 9:09 am
Might aswell, they alwas crap out anyway. and not having the extra heat in the t/b must have some small benefit
ChaosAD
