ra70 celica - 21rc engine - air pump seized
Postby FXGTV » Tue Jun 03, 2008 3:30 pm
The air pump on my good old 21rc engine has died - well the pulley wheel is seized, which caused the belt to rub and then smoke. I have removed the suspect pump, but am now wondering what, if anything else i should replace while im replacing the air pump. Also, would a faulty air pump damage anything else at all?
It ended up being blessing in disguise as a good 10 cm section of the timing belt is worn down to 1/5 its normal size!!!!!
I'm never buying a car off a chick again! :roll: :lol:
Cheers in advance guys.
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby FXGTV » Wed Jun 04, 2008 2:40 pm
someone must know something :)
FXGTV
Postby FXGTV » Fri Jun 06, 2008 4:29 pm
Anyone?
FXGTV
Postby FXGTV » Wed Jun 18, 2008 10:34 am
Hey guys. Has anyone ever changed over one of these pumps before?
They're also known as vacuum pumps and volution (sp?) pumps. I'm having a bit of trouble upon installing the new pump. Main problem at the moment are the tensioners..and then getting the belt back on, once the pump is bolted in place. (the belt gets in the way of the bolt that bolts through the tensioner bolt and into the pump itself).
At this stage any help at all would be great
FXGTV
Postby FXGTV » Fri Jun 20, 2008 12:42 pm
Bloody hell, i guess no-one knows anything about this old as celica :lol:
FXGTV
Postby xsspeed » Fri Jun 20, 2008 12:49 pm
probably true, I have no idea, just giving you some love on a pretty lonely looking thread
Postby evil_si » Fri Jun 20, 2008 1:45 pm
what does this airpump do?
mazda ones that im familar with just pump air into the exhaust, quite simply they dont need them
evil_si
Postby FXGTV » Fri Jun 20, 2008 4:20 pm
It pumps air from one side of the air filter 'hat' back into the pump and then round to the other side of the 'hat'. Its on the same belt line as the ac.
Cheers for making this thread look at least a little loved.
FXGTV
Postby FXGTV » Tue Jun 24, 2008 12:41 pm
fixed. The tensioners ended up being a real bitch, but once you work out which way round the bolts fit together its a piece of piss. So far its cost me nothing to fix 8) I'll post pics soon.
FXGTV
