Bleeding Clutch fluid
Postby xsspeed » Sun Jun 22, 2008 6:46 pm
Hey guys,
I'm having issues bleeding the clutch fluid through in my corolla.
I have replaced clutch components, and when I did obviously drained the clutch fluid. Now I have topped up the reseviour, loosened the nipple on the slave cylinder, (using a 1-way valve to bleed it), and depress the clutch pedal but nothing happens. The level in the reserviour drops a bit after a few pushes but then slowly comes back to the top.
Am I missing something?
Cheers in advance
Postby cat007 » Sun Jun 22, 2008 6:47 pm
the one way valve isn't working.
Do it the proper way - get a 2nd person to do the "tight" - "loose" - trick on the nipple. Easy
Postby xsspeed » Sun Jun 22, 2008 6:51 pm
sorry forgot to add, nothing comes out the slave nipple at all anyway
Postby pc » Sun Jun 22, 2008 7:02 pm
It's cos your lines are full of air. As above.
loosen nipple
press pedal down
tighten nipple
let pedal up
Repeat until the fluid pumps through.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby cat007 » Sun Jun 22, 2008 7:13 pm
If there is air in the master cylinder - it can take quite some time/pumps to get the fluid through.
Postby Akane » Sun Jun 22, 2008 7:15 pm
Do it the oldskool way.
When I replaced the clutch line on the misterpoo, it was one meeleeeon pumps per minute and still took 30mins+ to get ANY pressure.
Postby Jdawg » Sun Jun 22, 2008 9:00 pm
Also, is your clutch master cylinder double action?
Jdawg
Postby cat007 » Sun Jun 22, 2008 11:35 pm
Jdawg wrote:Also, is your clutch master cylinder double action?
As in pushes and pulls? How on earth do you bleed those bad boys?
Postby xsspeed » Mon Jun 23, 2008 12:49 am
hey cheers guys, yeah cat I think your right actually bout the one way valve, I had a think about while doing the laps around foodtown.
Maybe the one way valve will be sweet once the fuid runs through but until then theres a lot of air in the pipes. so old school way it is, so much for fancy one man bleeder kits, pisssshhhh
and no I doubt itd be dual action, its in a ee80 corolla. no bells or whistles
how would a dual action one work? does it assist the release?
Postby AE86less » Mon Jun 23, 2008 12:02 pm
I'll help with yours if you help with mine :lol:
I had been wondering why it was getting harder to change gears :oops: :oops: :oops: :oops:
Getting to the nipple on an AW is a bitch though.
EDIT: ^^ Pun :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Jdawg » Mon Jun 23, 2008 1:57 pm
You need a pressure bleeder. Easiest way to tell is to open bleed nipple, depress clutch pedal, close nipple, pedal stays depressed.
Jdawg
Postby Santa'sBoostinSleigh » Mon Jun 23, 2008 3:23 pm
i'll be running into this problem soon when i put everything back together on my AE92-c56-Blacktop hybrid, will the double acting thingamajiggy affect me?
or just the one meeeeleeeioon pumps in combination with nipple tweeking
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby 85AW20v » Mon Jun 23, 2008 10:36 pm
Or apply a bit of positive air pressure to the reservoir with the bleed nipple open. Fluid can't go anywhere except the right way. You only need to use a bit of garden hose and blow down it while sealing off the top of the reservoir with your hand. Been there done that on the AW.
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
