hey hunt, don't bother with 6*9's in the back, run a decient set of fronts, and just some 4"s in the rear boxes as rear fill, otherwise the sound will seem as it's coming from behind you. with the 12's the size of the 6*9's is a bit of a waste. in my old supra i had a 15 in the boot in a slightly too small box, ford telstar rears, and sony xes components in the front doors, staged real well, sound was crisp and in front of you, and the bass wasn't too in your face, but the whole system could still crank when i wanted it to.
with regards to the fibreglass, no idea sorry as to a place in aucks, but someone on here from there should have an idea. are you going to build it into the spare tyre well? or just so you can follow the lines of the boot interior? pics when you get it done
