Daihatsu Charade GTti problems - white smoke on idle
Postby Caboose79 » Sun Jun 29, 2008 5:07 pm
smokes a white smoke on idle (always when warm), sometimes misses on idle when smoking and deaceleration (sometimes) but not on boost smells like fuel... and i dont have a clue whats wrong
reacent changes is new fuel filter, had 2 replace flange gasket between turbo and exhast manafold, and brakes but that would have nothing to do with it. uses no oil, uses little bit of water not much but its gota water cooled turbo on it.
any ideas??
Caboose79
Postby ~SlideWays~ » Mon Jun 30, 2008 10:22 am
Is it definitely smoke? Could be steam from Blown Head Gasket.
Other than that it MUST be using oil, ie leaking oil through seals somewhere. Possibly valve guides (normally only after idling or on start up), piston rings, turbo seals etc etc.
~SlideWays~
Postby bbq1988 » Mon Jun 30, 2008 12:38 pm
rule out the turbo, maybe valves? just rebuild your other cb80!
Baked, Not Fried.
bbq1988
Postby TRD_ZERO » Mon Jun 30, 2008 7:04 pm
White smoke? Usually means burnt oil outside of the combustion chamber. Like turbo seals.
TRD_ZERO
Postby bbq1988 » Tue Jul 01, 2008 11:46 am
Turbo is under 3 months old, and was checked out in the weekend.
Baked, Not Fried.
bbq1988
Postby snwtoy » Wed Jul 02, 2008 10:39 am
Smoke under decelration is a good indicator of valve stem seals being poked. CB80s are a doddle to work on so replacing them won't be difficult.
snwtoy
Postby bbq1988 » Wed Jul 02, 2008 8:41 pm
Solved
Baked, Not Fried.
bbq1988
