groupagt4 wrote:will be puttong a 4agte in my ae86 soon.
Just a few question
What size intercooler will do for about 180-230kw atw
ive still got standard fuel lines and s/t pump will it be able to keep up.
what kind of clutch should i get 5 or 3puk?
groupagt4 wrote:oh thought id need one but i think ill blow the box before the clutch anyway. have you measured your intake temp by any chance. it would mainly be a street car with the odd drags,drift, trackday now and then
Dell'Orto wrote:If you want to go for a paddle clutch, more pucks = more drivability.
IH8TEC wrote:Dell'Orto wrote:If you want to go for a paddle clutch, more pucks = more drivability.
aint that the truth, or you could harden up and get a 3puk solid center with nice heavy pressure plate.
Paddle/Puck or Button
These clutches are sometimes quite unusually shaped and have relatively small areas of friction lining on each paddle. This serves to reducing the overall contact area acting upon the flywheel when compared to a full-face clutch. With no other accompanying changes, fitting one of these will give a higher maximum clamping pressure (pressure = force / area) and will therefore deliver more resistance to slip.
[...] there are, however, some problems with simply installing a paddle clutch with no other changes. Because the total contact area of the clutch is reduced, the rate of lining wear is increased, clutch engagement is more sudden and shudder can also be encountered on take-off.
postfach wrote:Just fyi, information taken from another forum:Paddle/Puck or Button
Are you in Auckland? Go to tradeparts on wairau road and have a chat to them about what you need, they're pretty switched on IMO and can suss something out for you.
Jonno2002 wrote:ive got the same setup in my gx81 escortman, sprung centre 4puk, piss easy to drive nowhere near as bad as i thort it would be. but yea if you want a bit more driveability then consider a carbon kevlar plate, thats whats in my civic and you can slip it when you want to with minimal shudder and when giving it sh*t its NEVER slipped on me, grabs like a puk.
i only went puk for shits and giggles really and cause i can
