Spark Plugs
Postby MAGN1T » Thu Jul 03, 2008 6:37 pm
Dell'Orto wrote:Steve - I bet you dont use copper plugs in the rear bank of your GTO do you? ;) (or do you have to remove the motor often enough to make it worthwhile? :P)
Platinums all round. Each time I've rebuilt the motor , I've put the originals back in. The only time I've had a problem was with a broken piston which smashed the plug(s). So long as the gap is OK and they're not fouled, there's no need to change them. If it's not broken , it doesn't need fixing. Colder plugs can cause misfires at low revs/low throttle.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby BZG Wagon » Thu Jul 03, 2008 9:08 pm
TRD Man wrote:But given their tendency to foul very easily I wouldn't recommend them in any application.
Tell me more...
8O ?!?!?!
BZG Wagon
