ae101 idler pulley
ae101 idler pulley
Postby Mike- » Sun Jul 06, 2008 12:34 pm
how the hell do i tension this thing, ive got the bolt going up through the ac bracket into the water pump pulley but tightening that does nothing, does it go up through something else aswell or what?
Mike-
Postby AceSniper » Sun Jul 06, 2008 12:58 pm
loosen the bolt that passes through the center of the pulley then wind the adjuster bolt and tighten the pulley again
AceSniper
Postby Mike- » Sun Jul 06, 2008 1:04 pm
ya but winding the adjuster bolt does nothing, the pulley (threaded bit) is just sitting on top of the ac bracket, im pretty sure im missing something but no idea what it would be,
Mike-
Postby AceSniper » Sun Jul 06, 2008 1:45 pm
turns easy? its not striped or anything? sounds a bit strange cant get a pic?
AceSniper
Postby Mike- » Sun Jul 06, 2008 1:48 pm
ok, the pulley bit is threaded and sits on top of the ac bracket bit (not threaded), when i tighten the bolt all that happens is the .....
oh $&#$% i had the belt sitting on top of the idler, problem solved thanks for your help :D
Mike-
Postby Mr Revhead » Sun Jul 06, 2008 9:40 pm
thats very easy to do :lol:
