Rumad wrote:Yes to the first. Can just piggyback the rca's off your fusion amp (or vice versa) or just run a set of y-splitter plugs but either way will work.
To the second question: Can but highly inadvisable. as soon as your monoblock hits a big bass note it will get greedy and take every ounce of power it can and will leave your other amp starved for power (possibly driving it to 'clipping' status). So in short no, take the time to run a dedicated wire from the battery, or a distribution block close to the battery) to the new amp
scotty_ish wrote:Rumad wrote:Yes to the first. Can just piggyback the rca's off your fusion amp (or vice versa) or just run a set of y-splitter plugs but either way will work.
Why distro close to the battery? As long as the primary cable is thick enough there is no reason not to distro it near the amps
Stott69 wrote:what if you had simalar set up to above but throw in a 1f cap in the mix? my battery is in the boot already, im running a sony 222 for my 6x9s, and a pyle PLA 2210 1800w to drive my kicker 10" square.
