Fitting and certifying ABS Brakes
Postby Infinite » Wed Aug 06, 2008 8:54 am
NZ_AE86 wrote:
Infinite wrote:u dont actuley have to cert going to/from abs ive removed abs in many cars. can u handel the power of the silvertop if u don't know howto brake without the help of abs?
You must get certification for removal or fitting of ABS.
well the toyota i setup without and also told the ms/cert guy about checked on it and said it dont also vtnz dont seem to have a problem with it to.
Lots
Infinite
Postby NZ_AE86 » Wed Aug 06, 2008 1:52 pm
First of all VTNZ are $&#$% clowns!
When a WOF is issued it must be in accordance with the VIRM. So if you were to bring a car to me and I could see that ABS had be added or removed then it would not pass a WOF.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Infinite » Wed Aug 06, 2008 6:06 pm
well added to that u wouldnt be able to tell ;)
Lots
Infinite
Postby NZ_AE86 » Wed Aug 06, 2008 7:46 pm
On the money! Yes if I have no way of knowing then I can't fail it of course. But if you are that good then there is a good chance it is a job well done and safe too!
I do believe you should always have everything cert'd just to cover your ass with insurance and other things - even if your conversion is as good as the factory could do.
Current rides;
1986 Levin GT
NZ_AE86
