Hi all
I need to sort out the oil feed for my turbo as the current 't' off the pressure sensor is leaking and less than optimal.
I have in my possession a metre or so of braided line, with an outside diametre of 7-8mm (I don't have a decent measuring tool). It looks like braided hose fittings are measured in 'AN' or 1/16 of an inch sizes. Converting 8mm -> 1/4 inch -> 4AN. Can someone confirm this would be correct?
The line currently has crimp connectors on both ends, which I don't trust.. they seem cheap and nasty. I also only need the hose to be about 25cm long.
Woudl I be better to replace these fittings (once hose is trimmed) with something like these ->link<-, or better to get someone to make up permanent fittings?
Are those prices on trademe reasonable (i don't care about having fancy blue/red stuff, just need it functional so brass would be fine)??
