4age transplant
4age transplant
Postby themaleman » Tue Aug 12, 2008 7:16 pm
what would be need to trasplant a bigport redtop 4age into this?
viewtopic.php?t=67942
shouldnt be to much involved right?
i have pretty much the whole car that the engine came out of,
the 4age is auto but i have a manuall box, and i hear the its not to hard to suss out the different engine looms
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby deaf_rattle » Tue Aug 12, 2008 10:24 pm
you will need to run an efi fuel tank and pump and you will need to wire in a circuit open relay.
Postby xsspeed » Tue Aug 12, 2008 10:33 pm
Yeah shouldnt be too much, mounts should be sweet, I dont know for sure about the cross member but would imagine thatd be sweet cos they are both 4a blocks.
You would need to suss fueling - pump for efi, efi rated rubber hose might need to be put in.
Im not sure about the ae92s but it might have drum brake rear, so you may want to swap the disc setup over from the parts car you have.
Might also be worthwhile to switch over some of the interior electrical work, just for fun!
You may also find it easier to suss out a manual loom for the bigport? I would have thought they are quite common?
Postby touge rolla » Tue Aug 12, 2008 11:59 pm
I put a 20V into my one of these, bloody easy. Though I think on the 16V the radiator hoses will have to be different, but that is simple enough. Clutch, fuel pump and fuel feed line and your sorted, the rest is the same iirc.
Of course I gave up when I had to do the wiring :lol:
touge rolla
Postby thaphatty » Wed Aug 13, 2008 12:11 pm
xsspeed wrote:I dont know for sure about the cross member but would imagine thatd be sweet cos they are both 4a blocks.
cross member doesnt touch the block in a fwd setup dingus.
will be a easy conversion even if your cabbage with wiring, just mash one of those trademe 5 wire looms on.
thaphatty
Postby xsspeed » Wed Aug 13, 2008 1:18 pm
not sure about ae92's but I'm pretty sure the block in ee80's ae82's mounts to the north south crossmember, seeing as I just did one :lol:
In saying that I know remember the *E9X series have a different crossmember setup to the *E8X series
Postby themaleman » Wed Aug 13, 2008 7:00 pm
matt is the 'circut open relay' for the auto side of things?
my engines out af a ae92 levin, would the fuel take be a straight swap?
and if i were to get a manuall loom would i need a manuall ecu? im pretty sure ive read that they are the same
thanks for all the replys!!!! :D
4agte ae92 Levin
a15 powered sj410
themaleman
Users browsing this forum: Bing [Bot] and 17 guests
