Hey there, have had a look through previous threads, but can't find anything directly relating to the issue I've found with my AE111.
After lightly accelerating, when coming slightly off throttle, the car will lurch a bit. It accelerates fine, and doesn't lurch when coming onto throttle, only when coming off. It doesn't seem to be rev or gear dependent (although I've noticed it mostly in 3rd and 4th), and its quite intermittent.
From similar threads, I've seen throttle position sensors mentioned, or possibly worn / damaged engine mounts ... any other ideas?
TIA
